20 Most Recent
321studios DVD X Show for PC Questions & Answers
Error 42 at start up
it isn't the program it is your computer. I have search for 20 minutes and found a link which should repair error 42. I have not tested it but from looking at reviews it is supposed to work. So... lets hope it works. All you have to do is download it and run the installation.Scroll down if you want to see the reviews once on the site.
PCHELPSTER007 from youtube
I have just upgraded to
Hi. Did you mean upgrade or downgrade? XP is older version than windows 7. Error you are getting means that the system cannot find the path specified. Are you installing the program using the the installer disk?
I can't load or find
First thing would be to download a free anti-malware program and also a free registry cleaner and optimizer called Glary Utilities !!!!!!!!!!! This should fix the problem. If by slight chance it doesn't then you will have to go deeper:
Make an uninstall list using HijackThisTo access the Uninstall Manager you would do the following:
- Start HijackThis
- Click on the Config button
- Click on the Misc Tools button
- Click on the Open Uninstall Manager button.
- Click on the Save list... button and specify where you would like to save this file. When you press Save button a notepad will open with the contents of that file. Save the file to your desktop.
Please post this log on your next reply.Please download
Malwarebytes' Anti-Malware and save to your desktop.
- Double-click mbam-setup.exe and follow the prompts to install the program.
- At the end, be sure a checkmark is placed next to:
Update Malwarebytes' Anti-Malware
Launch Malwarebytes' Anti-Malware
- Then click Finish.
- If an update is found, it will download and install the latest version.
- Once the program has loaded, select Perform Full scan, then click Scan.
- When the scan is complete, click OK, then Show Results to view the results.
- Be sure that everything is checked, and click Remove Selected.
- When completed, a log will open in Notepad. Please copy and paste the log back into your next reply
Note:
- The log can also be found here:
C:\Documents and Settings\Username\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\Logs\mbam-log-date (time).txt
- Or via the Logs tab when Malwarebytes' Anti-Malware is started.
NEXT If
MBAM will not run please rename it as explained below
1. Right click Start - Click Explore
2. Navigate to: c:\program files\malwarebytes' Anti-Malware Right click on mbam.exe - click Rename
3. Type into the name box: muppy.exe
NEXT Download and Run: RSIT
- Download random's system information tool (RSIT) by random/random from here and save it to your desktop.
- Double click on RSIT.exe to run RSIT.
- Click Continue at the disclaimer screen.
- Once it has finished, two logs will open. Please post the contents of both log.txt (<<will be maximized) and info.txt (<<will be minimized)
Register
I just threw it out. I don't want to spent money on advice. I thought that this was a site for people helping people.
Thanks anyway!
Installation guide
Very difficult to tell from here.
It could be a compatability issue, but you will need to contact them and explain to get a certain answer.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
