20 Most Recent Citizen BL5314 52E WR200 Eco-Drive scyba watch Questions & Answers
0answers
How do I manually set my Eco-drive wr200
Pull crown out 1 click to set day/date, set to one day behind actual date... Then, pull crown out an additional click to move hour/minute hands around to set exact date by hour/minute a complete 12-24 hour revolution if necessary to get AM or PM accurate for the proper day/date. :)
8/8/2014 2:50:50 PM • Citizen BL5314... • Answered on Aug 08, 2014
0answers
Manual set time on citizen wr200
you can get instruction off the link belowhttp://www.citizenwatch-global.com/support/guidhomee.htm
11/6/2012 5:02:59 PM • Citizen BL5314... • Answered on Nov 06, 2012
0answers
Daylight saving time
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
11/5/2012 3:03:28 PM • Citizen BL5314... • Answered on Nov 05, 2012
2answers
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals. Rate me, please
11/1/2012 12:55:54 PM • Citizen BL5314... • Answered on Nov 01, 2012
0answers
[email protected] is actually meant by
Daylight savings time is primarily an USA thing. We set our clocks ahead every Spring in March and hour and back an hour in the fall. The idea was invented by Ben Franklin centuries ago to save energy and it is still done with the same idea in mind. Read elsewhere to see how it saves energy, debatable. Not all part of the country observe DST. Just turn it off and you should be fine. You may need to correct the time.
3/24/2011 10:03:24 PM • Citizen BL5314... • Answered on Mar 24, 2011
0answers
I have a new Citizen
I cannot promise that the instructions will be any better than the ones you already have. Some makers only give the most rudementary instructions and expect you to know the rest. I hope this helps!
2/9/2011 7:25:30 PM • Citizen BL5314... • Answered on Feb 09, 2011
I have a Citizen Eco
Lower button is A and top button is B. How to adjust time Time can be adjusted in the Time mode. 1. After turning the crown counterclockwise to unscrew it, pull the crown out to the time adjustment position (the second click stop position), the second hand will stop running. 2. Set the watch for the correct time by turning the crown. 3. Press the- crown in to the normal position and the watch (second hand) starts running. 4. Turn the crown clockwise to screw it tightly against the case. When the crown is pulled to the time adjustment position, the function hand points at the "O" second position. If the function hand does not point at the "O" second position, correct the hand position referring to section "J. Setting Function Hand at "O" Position. ------------------------ How to set time? 1. After turning the crown counterclockwise to unscrew it, pull the crown out to the date adjustment position (the first click stop position). 2. Set the watch for the correct date by turning the crown. 3. Press the crown in to the normal position. 4. Turn the crown clockwise to screw it tightly against the case. Note: If date is adjusted when the watch shows a time between 9:00 PM and 1:00 am, the watch may not advance the date indication the next morning ---------- Note on operation of the crown> x The crown of this watch is designed to be screwed down onto the case to secure the water-resistance of the watch. x For pulling out the crown for adjustment, unscrew it to get it loose first. x After adjustment with the crown, press it in to the normal position and then screw it down with- out fail. x Do not operate any button while the crown is being pulled out. If a button is operated in such the status, it may cause some change in the indication or disorder of some hand(s). Do not pull out or turn the crown when the watch gets wet or is in the water. Otherwise, the watch loses waterresistance and the inside of the watch gets wet. --------------- H. Chronograph Made The chronograph function enables this watch to measure time in units of 1 second for a maximum of 49 minutes 59 seconds. When it has reached 50 minutes, since a time measurement was started, the chronograph stops measuring time and the hands move to the reset position. * If the watch is left in reset status in the chronograph mode for 3 minutes, it automatically switches to the Time mode. ----------------------- (1) In the Time mode, press and hold button (A) for 2 seconds or more to switch the watch to the Chronograph mode. As a result, both the function hand and mode hand quickly go to their respective "O" positions and then stop. (2) Each time button (B) is pressed, both the hands start and stop alternately. (3) If button (A) is pressed while both the hands are stopped, the chronograph switches to the reset status. ----------------- The watch cannot be switched to the Chronograph mode from the Diving mode. If the function hand or/and mode hand do not reset to their respective "O" positions when the watch enters the Chronograph mode or the chronograph is reset, adjust the hand(s) to the "O" position referring to section "1. Measures Against Possible Problems". The mode cannot be changed while the time is being measured in the Chronograph mode. If the mode is changed while in the stop-state of the Chronograph mode, then indication is cleared. ---------- This instructions will help.Thanks.Helpmech.
1/21/2011 4:45:28 PM • Citizen BL5314... • Answered on Jan 21, 2011
0answers
Citizen eco drive watch is brand new, but the
You should take the watch back to the dealer for exchange or refund since it would be under warranty, taking the watch apart will void your warranty leaving you unhappy with your purchase.
12/18/2010 1:10:56 PM • Citizen BL5314... • Answered on Dec 18, 2010
2answers
My Citizen WR200 keeps resetting to the year 2016
My Skyhawk AT is showing the wrong date and the year is 2016. How do I correct this?
The factory has discovered a software anomaly in the calendar programming of the integrated circuit that affects some Skyhawk AT and other styles utilizing the U600 movement caliber produced in only 2007 for those watches receiving either the U.S. or Japanese time signals. Those customers receiving the German time signals or have pieces manufactured in other years are not affected. This anomaly results in the calendar displaying dates from 2016 even though the year is 2010. Rest assured no other production series, feature, function, aesthetic portion or other Skyhawk series timepiece is affected.
If your 2007 production Skhyawk AT shows the year 2016, we are ask you to send the watch for updating.
Once your watch receives the software update, there will be a small dot punched on your caseback in front of the serial number. Our goal is to have your watch returned to you in two weeks once it is received by us.
If you are located in the United States,please email us the following information so that we may arrange a prepaid shipping label with UPS for you:([email protected]):
Your Name
Company (if you are going to return from your place of work)
Address (don't forget any apartment or suite number)
City, State, Zip Code
Telephone number
Email address
If you prefer, you may also call us at 800 321 1023 x4234 with the information. Do be aware that our telephones may be very busy so hold times could be longer than we would like.
Once the label is arranged, you will receive an email from UPS with instructions on sending your watch. Be sure to pack the watch securely in a sturdy box (do not send the original packaging or materials), tape the label to the box and submit the package to one of the many UPS drop off locations throughout the United States. If you are located outside the U.S, please contact your nearest service center for direction.
We appreciate your understanding and apologize for any inconvenience this may cause.
8/31/2010 6:45:17 PM • Citizen BL5314... • Answered on Aug 31, 2010
How do I set dual time
You can download instructions from the following site:
http://www.citizenwatches.co.nz/instruction-manuals
8/14/2010 11:23:32 PM • Citizen BL5314... • Answered on Aug 14, 2010
Citizen BL5314 52E WR200 Eco-Drive scyba watch Logo
39 questions posted
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
View Most Popular
Citizen Watches
  • Citizen Watches
Most Popular Question
new citizen
  • Watches
