20 Most Recent
Huffy Cranbrook 26" Mens Cruiser Bike Questions & Answers
The bike makes a loud noise when pedaling
I suspect the crankset or bottom bracket. It can have the illusion of tightness when not moving, but "clunk" everytime you pres on the pedals. I would first make sure that the cranks are tight on the bottom bracket axle. This will require a metric wrench.
How to change rear tire ?
Remove rear wheel with either a 15 mm or a 17 mm wrench. Take the tire off the wheel. If you are replacing a tire, reverse procedure. If you have a flat, replace inner tube, then reverse procedure
Parts for Huffy Maxx? I need a left side crank and nut.
Question moved from Computers to maker category.
Order Replacement Parts
Huffy Bikes
https://www.huffybikes.com > parts
We make it easy. Here you can order free warranty parts, or purchase the replacement parts you need. *Note: Battery products including ride-on toys, ...
Missing: Maxx ā' Show results with:
Maxx
Order Replacement Parts-Bikes, Scooter, Ride On Toys
Huffy Bikes
https://www.huffybikes.com > index > findproduct
Order replacement parts for your bikes, scooters, and battery ride on toys. ... and FAQs about warranties, warranty parts, returns and order cancellations.
Maxx
Huffy Vintage Bike Parts for sale
eBay
https://www.ebay.com > ... > Vintage Bicycle Parts
Get the best deals on Huffy Vintage Bike Parts when you shop the largest online selection at eBay.com. Free shipping on many items ' Browse your favorite ...
Bike Parts and Accessories
Huffy Bikes
https://www.huffybikes.com > parts-accessories
Results 1 - 8 of 8 - Bicycle parts, smartphone holders, repair kits, and officially-licensed accessories from Disney and Marvel allow you to get the most out ...
Maxx
Model and year of huffy bike serial # 4H114288
Not possible to ID by serial number, and even if it was it's not important. Huffy's are not valuable and parts are not specific to a particular brand, let alone year or model of bike. The model name is printed on the bike's frame. If not there bike has been cheaply repainted, possibly because it's stolen.
Needto lubricate rear wheel bearings on a huffy single speed bike
as most bikes do not have seals on the wheel axles , it is possible to lay the bike on the side , use machine oil on the hub and axle area and spin the wheel while allowing drops of oil onto the axle bearing hub area
or you can take the hub apart and fill with a very light grease
11/11/2022 12:13:34 AM •
Huffy Cycling
Answered
on Nov 11, 2022
How to put on a rear axle assemly on a 26 inch perfect frame mens dellusso huffy bicycle
Are you asking about the internal parts like bearings, races, and such, or are you asking how to lace a rim?
The first one is fairly straight forward, so I am guessing the second.
I have done quite a bit with bikes and never attempted since it is a science and art. There are a few youtube videos but they make it look so easy. One on the issues I hit when thinking about it is having a good tuning stand and dishing guide to get the rim to run in the middle if front wheel of a bit off center on the rear due to the gear cob. I gave up trying to find the tools, right spokes, (before internet) and opted to buy a whole rim.
https://m.youtube.com/watch?v=OYl4NO5m16Q
HOW TO DETACH TRAINING WHEEL FROM hUFFY tODDLER BIKE
- Begin by removing the outer nut. Using a 15mm spanner (closed end preferred), turn the nut in an anti-clockwise direction when looking at the nut from the same side as the nut is on (Dia.1 below)
- Next remove the outer nut, round washer, training wheel and square stabiliser washer. DO NOT loosen or remove inner nut!!
Do 10 speed huffy mountain bikes have master link on chain for removal?
No, they do not - a chain tool has to be used. Also, a 10 speed (2 gears in front, 5 in the rear) would be quite old, so the rear gear cluster (freewheel) will be worn as well as the chain, and also takes a specialized tool to remove. Replacing both on a Huffy will cost more than the bike is worth.
I just bought a huffy Sienna. Now the left pedal has come off twice. Any way I can get it ti stay on?
If it came off even once it was not installed initially with enough torque. At this point there is a good chance the threads on the crank are damaged badly enough that the problem will reoccur. If you bought it assembled return it and complain. If you assembled it's your error, and a good idea to go over all other tighteners and adjustments. Loctite is unlikely to cure the problem. A bike shop may have to install a "Helicoil insert" to fix it, or replace the crank arm.
