20 Most Recent
Casio Atomic Timekeeping Waveceptor Watch WV59DA Questions & Answers
Accuracy after decimal?
Perhaps ten times more accurate than you can read. Lots of stopwatches go to one thousandths of a second, while the person pressing the buttons has a reaction time that can vary from one tenth to half a second. And every time the reaction time changes. So if it is not electronically is started and stopped, don't bother the accuracy of the watch.
How do I replace the battery on this watch?
Spread the towel out on a flat surface.Remove the watchband if necessary in order to access the back of the watch.Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.Remove the rubber protector to find the battery.
Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.Remove the old battery with tweezers.Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.Replace the clasp over the top of the new battery.Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.Replace the rubber cover.Replace the back plate by screwing the small screws back into place.Replace the back protector by screwing the small screws back into place.Reattach the watch band to the watch face.
Thank you!
Battery replacement
do you mean you want to replace the battery for your watch?
This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
Good luck.
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
How to fix Quartz on my casio 708 mtp 3036
This is a job a specialist watch repairer should do. It will need specialist tools so if you are not familiar with working on watches pay someone to do it for you. Also consider the cost of repair. It might be cheaper to simply buy a new watch.
