20 Most Recent Casio G-Shock Atomic MTG930DA 8VCR watch Questions & Answers
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Casio G-Shock... | Answered on Mar 14, 2011
In order to remove the links of your Mtg930 watch you will need a couple of tools . It is recommended to have a watch pin pusher and a spring bar remover tool in order to do so. If you do not you can use a small precision flat head screw driver , the size that is usually used to fix glasses or smaller.
First you need to lay a cloth down at a table . Lay the watch on top of cloth to prevent scratching . flip the watch upside down and have a good at the back of the watch bracelet.
If you look carefully you are going to see notches on the back of each link with an arrow pointing in. This is where the spring bars are accessible and can be pushed in to remove the link.
You need to place your spring bar remover, pin pusher or precision screw drive in the notch against the edge.
Mean while push the opposite side of the watch link up so you can see the most of the spring bar inside the notch.
The spring bar is going to look like a pink with a notch on the the top then gets smaller. As shown below on the left side of the picture. If you are looking at the notch on the spring bar, that is where you need to get our tool ontop of . So you can push down the spring bar.
Once you push down on that notch on the spring bar the link will be able to slip out . Without a spring bar remover it will be more difficult and you will need to be patient as you try to work your flat head screw driver into the notch and be able to push down . Once the pin is push down you need to pull the link from the rest of the bracelet.
Do not be surprised to take anywhere from 5 to 30 minutes if you have no experience and not have a spring bar remover.
Once you removed all the links you desire , You will need to put the spring bars back into the links and close the watch bracelet up.
The easiest way is to slip spring bar into middle of link. Bring the other end of the bracelet over so it the bottom covers the other link with the spring bar head out. Push the spring bar down with your tool as you slide the links back together.
Casio G-Shock... | Answered on Oct 18, 2010
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please.
Casio G-Shock... | Answered on Mar 31, 2010
You can get instructions from the Casio web site.
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
Casio G-Shock... | Answered on Mar 19, 2010
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please
Casio G-Shock... | Answered on Mar 14, 2010
The watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
http://antiqueclock.clockstop.com/
do a manual receive procedure
if you don't have the manual here's the procedure:
1-place the watch near the window (try to be on a clear area), the watch must be stable and the 12 o'clock side facing the window
2- press the D button for 2s untill the watch beeps
3- release the D button a message RC will be displayed
4-it take from 2 to 5 min to the signal to be acquired
hope it helps
give feed back
Casio G-Shock... | Answered on Apr 03, 2009
Hi Jamie, the best thing to do is take it to a qualified Jewler/watch repairer.
Casio Watches | Answered 18 hours ago
My Dad has one of these watches, his battery is dead where can I get the battery to replace it?
Casio Watches | Answered on May 13, 2019
Unplug it for a couple minutes and then plug it back in to see if it will start up again, if not look in your instruction manual. If nothing about it, contact the company of your machine
Casio Watches | Answered on May 11, 2019
CTL1616 and there is a video on you tube showing you how to do it.
I assume this is the casio Forester.
Casio Watches | Answered on May 09, 2019
Google (casio)(AE 1200 WH)(manual) without parens for instructions.
Casio Watches | Answered on Apr 02, 2019
Casio G-Shock Atomic MTG930DA 8VCR watch Logo
17 questions posted
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
want shorten watch band new casio
  • Watches
