20 Most Recent
Casio AMW700B 1AV Pathfinder Watch Questions & Answers
Need to replace the band.how can i get it
You may be able to get a replacement strap direct from Casio. If you go to "casio.com/" and click on "support", you will find a menu on the left.
Click on repair and service and you will have two optional places to buy parts. There is no parts list but you can speak to them about your needs.
If you want them to fit a strap for you, then the service center is the place to contact.
Lost maual to amw-700 casio watch
advance the mode 6 times to H S mode and push left upper button till the digital time flashing, then push rigth doun or up buttons to advance, please read manuals
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
How to fix Quartz on my casio 708 mtp 3036
This is a job a specialist watch repairer should do. It will need specialist tools so if you are not familiar with working on watches pay someone to do it for you. Also consider the cost of repair. It might be cheaper to simply buy a new watch.
