20 Most Recent
Anne Klein 10 6927SVSV Watch for Women Questions & Answers
Need to remove link from Anne Klein 12/1979
You will need a small jeweler screwdriver set Home Depot or Lowes to push the pin out. If you look close you will see the pin in one side is slightly larger than the other. you need to push on the smaller of the two sides of the pin. be careful not to scratch the watch, and you will also need a gap in whatever you are using as your surface for the pin to be depressed into. A small block of wood with a hole in is will work well. Carefully push out at least two of these pins estimating how much you will need on each side of the band. you want to make sure the watch is centered on your hand once you have removed the links you do not need. It may be possible that you will need to put back one on one side and remove two on the other.
What size battery for Anne Klein watch 12/6187
Take your watch to a qualified local watch repair center or jeweler to have the battery replaced. It is very important that a battery is replaced by an experienced professional who can properly seal the back of the watch to prevent damage to the movement.
