20 Most Recent Tag Heuer (27mm) Link Quartz WJF1354.BB0581 Steel/Gold, Fine Brushed & Polished Bicolor Bracelet with Double Safety Clasp In Solid Steel Watch for Women Questions & Answers
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • 11/6/2014 10:48:56 PM • Tag Heuer Link... • Answered on Nov 06, 2014
    Is This a genuine Tag Heuer watch Serial number 70076507
    How would one know from the serial number. Numbers are easier to copy than even watches!
    10/1/2014 6:11:29 PM • Tag Heuer Link... • Answered on Oct 01, 2014
    Instruction manual
    If the second is ticking as normally it is not the battery. If the battery is low the second hand will advance only at 5 second intervals meaning for four seconds the second does not move and on the 5th second it will advance by five seconds. This is a feature unique to Tag Heuer.
    1/1/2014 4:58:51 AM • Tag Heuer Link... • Answered on Jan 01, 2014
    The minute hand seems to running wild (loose)
    you need to take mechanism out to push it back on, this link will help youhttp://www.pmwf.com/Watches/Watches.htm#WatchSchool
    9/13/2013 1:24:26 PM • Tag Heuer Link... • Answered on Sep 13, 2013
    Tag Heuer Women 934.208 works fine but couldn't adjust date or time
    send in for repair to a watchsmith
    1/22/2022 1:06:18 PM • Tag Heuer... • Answered on Jan 22, 2022
    2answers
    What kind of watch winder do I need for this watch
    You have selected a wonderful watch... Heuer and TAG/Heuer should be gently wound by the motion of the human wrist and the falling of a centrally pivoting weight (there is no ideal direction). AUTO-WIND function is NOT at all unique to your watch... After a couple of CHEAPER "winders" failed me... and after I figured about 4 watches was more than enough to keep wound... I found the greatest BASIC watch winder... to run year over year (efficiently and quietly) MTE watch winder (their very basic WTS-4). Good luck: I WILL try to include the URL (see page 6) http://mte-watchwinder.com/fileadmin/PDF-Uhrenbeweger/MTE_Watch_Winder_Brochure_Engl.__09-2015.pdf
    7/30/2020 12:51:36 AM • Tag Heuer... • Answered on Jul 30, 2020
    I have a tag Heuer kirium model cl111a how do you adjust the time on it
    Contact manufacturer they will help. :-)
    7/17/2019 1:18:31 AM • Tag Heuer... • Answered on Jul 17, 2019
    Tag Heuer (27mm) Link Quartz WJF1354.BB0581 Steel/Gold, Fine Brushed & Polished Bicolor Bracelet with Double Safety Clasp In Solid Steel Watch for Women Logo
    Popular Tags
    1 questions posted
    Top Tag Heuer Watches Experts
    k24674
    Sean Wright
    Sean Wright
    Ngoro
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
    View Most Popular
    Link Tag Heuer
    • Link Tag Heuer
    Most Popular Question
    self winding not work
    • Watches
