20 Most Recent
Tissot T Classic Seastar II T55.8.283.11 Automatic Watch Questions & Answers
Bought a 1970s tissot automatic
A self winding watch will run for 2-3 days if it is not worn (they thrive on being used) and it sounds as if you have not been using it; is this the case?
It could be that the winder does not operate on the spring (some watches don't), so to wind it up you need to activate the self winding mechanism.
You can do this by gently swinging the watch from side to side for a few minutes. This will simulate the normal operation when it is being worn.
If you continue to have trouble with it stopping, it could be that it needs cleaning. I had a similar problem with a watch I had some years ago.
Wot size battery do I need for a t472 tissot trace
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
Why Touch does not work after battery replacement?
Was the battery empty in the first place, or was the watch already defect?
Did you put in the correct and a new battery? or perhaps you did put n the old battery?
can you measure the voltage of the batteries, to check?
Just a few questions that came up with me.
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase
there is a sunken button between the chronograph start/stop and the winding crown.
Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
