20 Most Recent
Tissot Ballade T39.1.481.32 Watch for Men Questions & Answers
Wot size battery do I need for a t472 tissot trace
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
Why Touch does not work after battery replacement?
Was the battery empty in the first place, or was the watch already defect?
Did you put in the correct and a new battery? or perhaps you did put n the old battery?
can you measure the voltage of the batteries, to check?
Just a few questions that came up with me.
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase
there is a sunken button between the chronograph start/stop and the winding crown.
Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
How to open the Tissot PR50 back to replace its battery?
A water resistant watch usually has a back that screws into the case and seals with a rubber O ring.
Sometimes the back can be very tight to unscrew so even with the dedicated wrench it is difficult to remove without damage to the case. The professional would disconnect one end of the bracelet and clamp the case into a special holder.
Once a non-dealer has replaced the battery it is usual to discover the back isn't replaced as tightly as original - this is reflected by the usual warning the watch will no longer be waterproof. The only way to retain the waterproof or water resistant quality is to have the battery replaced by a dealer or manufacturer when it will be, if required, pressure tested.
