20 Most Recent PaceMaster Bronze Basic Treadmill Questions & Answers
0answers
0answers
Treadmill will not start up error comes up in window
please LUBE the deck belt with silicone or was see the owner manuals and proceed according. However if after you did lube the problem remain, is TIME to replace the old deck board.
God bless you
5/28/2013 6:16:54 PM • PaceMaster... • Answered on May 28, 2013
0answers
PaceMaster Bronze Basic err 119
Run the software calibration for easy diagnose, and troubleshooting see the steps. and Block diagramGod bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
1/14/2013 5:51:19 PM • PaceMaster... • Answered on Jan 14, 2013
Bronze Basic Treadmill Your question about Bronze Basic Treadmill has been posted. i have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks s
yes there are some reset button see your owner manual and do it. if you do not have owner manual download for freeLUBE the deck belt and rollers bearing inmediately.www.fitness.manualsonline.comHappy New Year. God bless you
1/2/2013 1:21:57 AM • PaceMaster... • Answered on Jan 02, 2013
I have a treadmill pace master bronze basic i try to start the machine and i get code 133 so ho can help me thanks solli On 2013-01-01, at 1:32 AM, FixYa.com wrote:
RESET the machine and try again.However if you can get again the code, Lube the deck belt and rollers bearing very well.Test the motor and controller motor see the block diagramsee the video and proceed according.Happy New Year. God bless you1_1_2013_10_56_57_pm.gif
1/1/2013 10:57:26 PM • PaceMaster... • Answered on Jan 01, 2013
PaceMaster Bronze Basic Treadmill Logo
24 questions posted
Top PaceMaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • PaceMaster Exercise & Fitness
Most Popular Question
treadmill will not start up error comes
  • Exercise & Fitness
