20 Most Recent Sole Fitness Sole E55 Elliptical Questions & Answers
Why is the the resistance on my sole e55 remaining easy to spin regardless of which resistance setting I select?
Belt could have come off. if the belt did break or come of it would be very easy to spin pedals. Flywheel ( brake ) could have jammed up. Loosen the covers and look for the brake cable that's connected to the resistance motor. Then run the resistance up to 20. If cable feels loose , the brake is stuck. Sometimes you can pull on the cable and it will free it up.
9/2/2023 5:47:15 PM • Sole Fitness... • Answered on Sep 02, 2023
How to fix a vibration problem on my eliptical trainer
Replace the drive belt
7/10/2023 8:06:55 PM • Sole Fitness... • Answered on Jul 10, 2023
Sole 55 elliptical scratching grinding sound
The rear wheels jumped off track or you have a bad flywheel.
2/8/2019 2:13:34 PM • Sole Fitness... • Answered on Feb 08, 2019
Lube sites for sole 20
Tracks only
3/5/2015 2:19:48 AM • Sole Fitness... • Answered on Mar 05, 2015
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals. You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message. Thanks Tyler! Happy exercising!
1/22/2015 2:36:55 PM • Sole Fitness... • Answered on Jan 22, 2015
2answers
Why did I suddenly lose resistance and smell burning on my sole e55 elliptical?
proceed according. iF THE problem persis after you LUBEt, TIME to replace the old board deck belt.God bless you
8/18/2014 11:33:50 PM • Sole Fitness... • Answered on Aug 18, 2014
0answers
Display Problem
Yes, you do need to either replace the entire console (4 screws) or the display board.
1/4/2014 8:27:29 PM • Sole Fitness... • Answered on Jan 04, 2014
0answers
Machine is Quivering while excersisng
follow this steps and fix it. God bless you Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs. Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright. Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
11/14/2013 11:49:29 AM • Sole Fitness... • Answered on Nov 14, 2013
Quivering while excersising
follow this steps and fix it. God bless you Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use. Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright. Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
11/14/2013 11:47:19 AM • Sole Fitness... • Answered on Nov 14, 2013
0answers
0answers
Sole Fitness Sole E55 Elliptical Logo
Popular Tags
26 questions posted
Top Sole Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Sole Fitness Exercise & Fitness
Most Popular Question
sole 55 elliptical scratching grinding
  • Exercise & Fitness
