20 Most Recent Epic A30T Treadmill Questions & Answers
0answers
My treadmill wont re-boot
follow this steps and fix it. God bless you Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
11/11/2013 10:39:42 AM • Epic A30T... • Answered on Nov 11, 2013
0answers
Need safety key
Be the first to answer 11/4/2013 5:03:47 AM • Epic A30T... • Posted on Nov 04, 2013Be the first to answer
SPEED OF TREADMILL ACCELERATES
please RUN the software calibration go under the HOOD motor and see the instruction, for easy diagnostic and fix it.God bless you
7/11/2013 11:48:34 AM • Epic A30T... • Answered on Jul 11, 2013
My treadmill will not connect to wifi.
go to https://www.ifit.com/installinstall that update and try again, this will be fix it.you will need adobe go http://get.adobe.com/airGod bless you
1/14/2013 9:07:03 PM • Epic A30T... • Answered on Jan 14, 2013
0answers
Epic T60 treadmill motor on 1-2 sec. then go off
Here are a few things you can try to troubleshoot the issue:
  1. Check the power supply and make sure that the treadmill is plugged in and receiving power.
  2. Check the fuse or circuit breaker to make sure that the treadmill is not tripping any electrical circuits.
  3. Make sure that the motor and controller are properly connected and functioning correctly. You may want to check the wiring and make sure there are no loose or damaged connections.
1/2/2023 10:33:17 PM • Epic Exercise &... • Answered on Jan 02, 2023
How to troubleshoot and repair monitor on EPIC 420R recumbent bike?
Question edited. Wrong type of peddle/pedal :>) See if you can get in behind the monitor and look for a fuse on the motherboard to it. The manual gives a bit of routine maintenance information and it does has a full parts schematic with contact to Icon Health and Fitness, the distributor for spares. https://www.manualslib.com/manual/568149/Epic-420-R-Bike.html?page=17 https://www.google.com/search?q=troubleshoot+and+repair+monitor+on+EPIC+420R ..
1/12/2022 8:34:20 PM • Epic Exercise &... • Answered on Jan 12, 2022
I am trying to connect my epic a35t to home Wifi, but touchscreen is not working
This appears to be a Treadmill rather than a Tablet / eReader? Category moved to Epic Treadmill. It appears to be a known issue and there are various fixes including reinstalling the Android Operating System for the display. https://www.google.com/search?q=epic+a35t+reset ..
12/1/2021 5:42:02 PM • Epic Exercise &... • Answered on Dec 01, 2021
Epic A30T Treadmill Logo
Popular Tags
19 questions posted
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Epic Exercise & Fitness
Most Popular Question
treadmill wont re boot
  • Exercise & Fitness
