20 Most Recent
Geneve 14K Solid Gold Octagon with Diamond At The 12 Watch for Women Questions & Answers
Need a new battery but
you should just contact the company directly
Geneva Watch Group
1407 Broadway
Suite 400
New York, NY 10018
Phone: 1-888-GWG-TIME begin_of_the_skype_highlighting 1-888-GWG-TIME
end_of_the_skype_highlighting
(888-494-8463 begin_of_the_skype_highlighting 888-494-8463 end_of_the_skype_highlighting)
Fax: 212-221-9414
or go to this link
http://www.genevawatchgroup.com/contact_form.shtml
They are the company that makes the watches. They can help you give you some address you might be able to mail or take your watch 2. good luck and best wishes.
Reset time on pocketwatch
Hi Tarynlarson,
Ok this can be done by GENTLY pulling out the crown till you hear or feel 2 clicks. Sometimes the crown has to unwound first, as you have not mentioned a specific model I am trying to be through.
Then you canjust rotate the crown and the hands should move and you can get it to the desired time.
When you have finished simply rescrew the crown back down.
Hope this helps?
Pocketwatch runs fast
Such a fast gaining usually is caused by dirty or magnetized hairspring, resulting in uneven coil amplitude (some of the coil rows are sticking together or touching each other). This causes the watch to run unbelievably fast.
To get the watch properly fixed you need to give to the watchmaker.
Alternetively; you can fix it yourself, but it will not last long.
For this you will need:
Case opener,
Dust blower (resin ball with nozzle),
Lighter fluid (ZIPPO),
Dropper (like one in eyedrops package).
Do as follows:
Open watch caseback,
Check for the fastest moving part in watch movement and you will see the hairspring fitted on it (pulsing outwards and inwards very fast).
Fill the VERY CLEAN dropper with lighter fluid.
Put ONE drop of lighter fluid on hairspring (DO NOT TOUCH IT),
Wait for a 10 seconds,
Dry out the lighter fluid with dust blower by vigorously squeezing it and pointing the nozzle on to hairspring from approx. 2-3 inches away.
Lay the watch on the table (dial down) and cover it with a clean, dustless cup. Leave for 15 minutes.
Fit the caseback on and enjoy your watch again.
Do not forget to rate, please.
My watch stop and it
Your watch needs to be clean,so that the old oil will be taken out,and change it with a new fresh oil.Old oil can caused the machine to stop,because old oil become sticky causing machine small gear stuck up and gear shafting can't move .
Hope it may help you;
Regards;
VOTIT
How do I set time.? No manual, remote does not work.
- Buttons on the Device: Look for any buttons on the device itself. Sometimes, there are buttons that allow you to navigate through menus and adjust settings directly on the device.
- Trial and Error: Try pressing different buttons on the device to see if any of them bring up a menu for setting the time. Look for buttons labeled "Menu," "Setup," "Clock," or similar.
- Long Press: Sometimes, pressing and holding certain buttons on the device can activate different functions. Try pressing and holding various buttons to see if it triggers a menu for setting the time.
- Google Search: If you know the model number of your Ultech device, try searching online for the manual. Many manuals are available for download from manufacturer websites or other online sources.
- Contact Manufacturer: If you're unable to find the manual online or if you're still having trouble setting the time, try reaching out to Ultech's customer support. They may be able to provide you with guidance on how to set the time on your device.
- Replace Remote Batteries: If the remote isn't working, try replacing the batteries. Sometimes, a non-functional remote can be as simple as dead batteries.
2/28/2024 9:57:13 AM •
Watches
Answered
on Feb 28, 2024
Skmei watch 1163- Daylight savings time- how to set
To set the Daylight Savings Time on your SKMEI 1163 watch, first press and hold the "MODE" button for approximately three seconds until the "SET" mode appears. Then, press the "MODE" button again until you reach the "DST" mode. Use the "ALARM ON/OFF" button to toggle between "ON" and "OFF" for Daylight Savings Time. Once you have set your desired option, press the "MODE" button again to confirm and exit the setting mode. Your watch should now display the correct time, accounting for Daylight Savings Time.
2/16/2024 11:07:11 AM •
Watches
Answered
on Feb 16, 2024
