20 Most Recent
Telemania 027367 Spiderman Animated Phone Questions & Answers
Very loud buzzing
The sound can also be caused by a faulty outside line. You can bring in a different telephone (like one at your house) and see if the buzzing sound disappears. If not its either a line problem or a jack/wire problem.
Multiple Telephone System Compatibility Issues
I most cases it should not matter that you have different phones to 1 phone line. You should make sure that all the phones are running off the main feed box for your property and not off each other. Check that all the wires are connected in each port and that the phone line running between the phone itself and the feed box does not exceed 50 feet because this can cause the phone to echo or not work at all.
Telemania Golf Remote
try pushing the program button,enter code and push program again,should blink twice or 3 times if it is a good code?
What is direct marketing?
Hello
Direct marketing is a sometimes controversial sales method by which advertisers approach potential customers directly with products or services. The most common forms of direct marketing are telephone sales, solicited or unsolicited emails, catalogs, leaflets, brochures and coupons. Successful direct marketing also involves compiling and maintaining a large database of personal information about potential customers and clients. These databases are often sold or shared with other direct marketing companies.
for more information visit
http://www.wisegeek.com/what-is-direct-marketing.htm
Hope this helps if so do rate the solution
3/21/2024 10:02:08 AM •
Lands Phones
Answered
on Mar 21, 2024
SONIM XP 3800 VOICEMAIL INDICATOR STAYS ON BUT,NO MESSAGES=?
TRIED POWERING OFF-PROBLEM STARTED 2/WEEKS AGO.
1. First, try resetting your phone by powering it off completely and then turning it back on after a few seconds. This can sometimes resolve minor software glitches.
2. If the problem persists, you can try contacting your mobile service provider and ask them to reset your voicemail on their end. They might be able to resolve the issue from their system.
3. Another option is to manually check your voicemail and listen to any existing messages. Sometimes, even if you've listened to a message, the indicator might stay on. By checking your voicemail and ensuring there are no unread messages, it might help clear the indicator.
If none of these steps work, it could be a more complex issue that might require technical support from Sonim or your mobile service provider. They should be able to provide further assistance. Let me know if there's anything else I can help with!
2/5/2024 4:27:32 AM •
Lands Phones
Answered
on Feb 05, 2024
