20 Most Recent Zojirushi ECBD15BA Coffee Maker Questions & Answers
I turn it on, light goes on, but nothing else. No noise whatsoever. Under a year old....
Same thing happened to me but I took it apart and ohm's tested all available wires going to the heating element and found out that one of the white insulated wire actually got hot enough to become fractured causing an open circuit after cleaning it back up and fixing the circuit. The coffee maker works once again
10/26/2015 3:08:06 PM • Zojirushi... • Answered on Oct 26, 2015
0answers
Water won't heat
Be the first to answer 10/15/2014 4:42:31 AM • Zojirushi... • Posted on Oct 15, 2014Be the first to answer
0answers
0answers
After filling up with water.....it will just stop
If it doesn't make heating noises, then the heating element is probably burned out. You should look into a replacement, but normally it's cheaper to just get a new Coffee Maker. If it does make heating noises, try the vinegar again - sometimes it takes ten or more times to get all the scale cleaned out, and sometimes a chunk of scale will break away and clog it up. If you run the vinegar through again it may dissolve the chunk enough to get it out of the way.
3/27/2010 3:37:18 PM • Zojirushi... • Answered on Mar 27, 2010
Coffee has doesn't drain into the carafe and just
1. Don't overfill the basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine or too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Make sure that the Pause 'n Serve isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Make sure the coffee machine is sitting level on the counter.
1/4/2010 5:31:27 AM • Zojirushi... • Answered on Jan 04, 2010
Zojirushi coffeemaker EC BD-15 display shows incorrect time. I.e., 1:62. Is there a way to reset the digital clock?
The digital clock or the control board may be defective.
11/17/2020 10:48:42 PM • Zojirushi Coffee... • Answered on Nov 17, 2020
Dear Sirs, I hope you can assist me. The plastic
Suggest you contact your nearest Zojirushi Service Center:
http://www.zojirushi.com/support/service_center.html
or contact their central Customer Service:
http://www.zojirushi.com/support/customer_service.html
3/13/2011 3:44:00 AM • Zojirushi Coffee... • Answered on Mar 13, 2011
Schaerer SCP is not rinsing correctly
Check the Operating Temperature: Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding. Check for Ongoing Programs: If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee. Inspect the Brewing Unit: Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position. If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly. Inspect the Coffee Spout and Drainage Area: Check the coffee spout for any clogs or blockages. Clean it if necessary. Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage. Refer to the Operating Manual: Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
4/20/2024 9:02:57 PM • Coffee Makers &... • Answered 2 days ago
Dolce Gusto Coffee Machine. The cold water is working, but nothing coming out of the hot side. No sound, no water, but the cold works fine.
They make a thousand models. It sounds like the heating element has failed. Generic help and videos in the link but these machines need dealer service at regular intervals depending on the complexity of the particular model. https://www.google.com/search?q=Dolce+Gusto+coffee+Machine+no+hot+water ..
4/17/2024 5:11:02 PM • Coffee Makers &... • Answered on Apr 17, 2024
Question about the De Longhi Magnifica coffee machine.
These machines need dealer servicing every 6 to 12 months. They don't tell you that when you buy them. There are some ideas here https://www.google.com/search?q=De+Longhi+Magnifica+warning+triangle ..
4/16/2024 2:41:15 AM • Coffee Makers &... • Answered on Apr 16, 2024
SCHAERER VERISMO 701 AMBIANTE 15 ESPRESSO MACHINE. We have to reset the Verismo 701 continuously even when we have the beans container filled up to the top.
Question edited for clarity. These machine need dealer servicing every 6 to 9 months depending on usage. They don't tell you this when you buy them, but I have been fighting these types of machines for the 9 years before I retired. One place had 2 machines and another has 6. Once machine did 1,200 cups a days and was serviced every month. Airport Business Class Lounges. ..
4/12/2024 5:42:30 AM • Coffee Makers &... • Answered on Apr 12, 2024
2answers
Where can I find Cecilware 3K-GB-LD Cappuccino machine Error Codes, I'm getting ERR 1 on my machine
To find Cecilware 3K-GB-LD Cappuccino machine error codes like "ERR 1," refer to the machine's user manual or technical documentation. Alternatively, contact Cecilware customer support for assistance in diagnosing and resolving the specific error code on your machine.
4/6/2024 8:13:43 PM • Coffee Makers &... • Answered on Apr 06, 2024
Capresso "Perk" Percolator Coffee Maker, 12 Cup. I have 2 percolator model 405.05 and the cord burned out on both i would like to replace the cords
Question edited for a lot more clarity. This is a very standard appliance plug that you can get from Walmart, Home Depot any small appliance store or even Amazon https://ecscoffee.com/products/capresso-12-cup-perculator-405-05 They look to be here https://www.google.com/search?q=percolator+model+405.05+replacement+cord ..
4/3/2024 6:29:51 PM • Coffee Makers &... • Answered on Apr 03, 2024
Zojirushi ECBD15BA Coffee Maker Logo
11 questions posted
Top Zojirushi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Zojirushi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Zojirushi Coffee Makers & Espresso...
  • Zojirushi Coffee Makers & Espresso...
Most Popular Question
turn light goes but nothing else no
  • Coffee Makers & Espresso Machines
