20 Most Recent
Festina 16177 3 Watch Questions & Answers
Need user instruction download for
A user manual may not exist. However this eHow Article may assist you if you have a simple problem:
http://www.ehow.com/how_6162541_set-festina-watch.html
Festina date set
if you go to Festina.com and select downloads and then enter your Festina watch number you can download the entire manual.
Good luck
Is there any way to adjust the band without a
Use a sturdy pin or thumbtack to push out the pin from the little hole on the link.
Make sure to examine the watch and which links have pins.
Some watches are designed to have a row of removable links with pins.
Remove one end of the band from the actual watch itself. Then remove links as you see necessary.
You may need to use something a little stout like a butterknife to tap the pins out from the links.
The pin on the watch itself has spring loaded tips, push them in and it should release the watch from the band.
