20 Most Recent
Archos 16GB 97 Carbon 9.7" Tablet Questions & Answers
Tablet wont charge?
Is the charge light coming on? I had the same thing with my daughter's netbook. Eventually, it wouldn't charge at all and had to be run attached to the charger all the time. I ended up replacing the battery and it works fine now.
Good luck.
Paul
Factory Reset for Archos 97 Carbon
I have forgotten the password for my 97 Archos carbon tablet.I would therefore like you to sent me the Information as to how I can reset it back to the factory settings please.I also have no data on it, I just want my Archos 97 back.Look forward to hearing from you soon Frank.
Internet
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
hope this helps
