20 Most Recent
Olympia CDP 24201 Cordless Phone Questions & Answers
Mexican buyer
Pulse el botón verde, cuando se desea hacer una llamada telefónica pinchie embesi.... leer las instrucciones, en español, faboso
Hello! I have an olympia
Well you can download the user manual from the below link -
http://www.amytel.net/uploadFiles/D42807F02D7DA0E0_3929103.zip
You can call 866-537-0384 to get the software of your phone.... there is no software release for your phone on internet.
Good Luck!!
Thanks
Need maual for CDP 24201
http://www.amytel.net/download_file.asp?ID=D42807F02D7DA0E0
There you go..
That is the URL for the manual.
LOOKING FOR THE SOFTWARE/Driver still !!!!
My Olympia cdp 24201 has no sound i called it from
you just need to take the battery out and wait 30 seconds, replace it
and it should be able to find the base. i had this problem and called
olympia and this is the fix they gave me. It's worked for 4 years!
Olympia cdp24201
1. go to menu, then HS setting, then registration, register
2. follow the steps and register the set to the base.
3.press and hold the base mute button for 10 seconds, press next to continued
4.select the cbs and connect it.
5.enter 0000 as a password
Software
I may have come across the software for you.... mind you, i don't know if anyone cares at this point but if you do, or anyone does want it, email me at "get DOT me AT hotmail DOT com" DOT being a period ( . ) ie: get.me okay? the more users who email, then i will post it for public download, should the need be great enough as it is 36 MB.
Olympia cdp 24201 cordless
need more info but thats a new model and most have warranty, have you benig used before or is the first time can you see some indication of be in charging mode..post back..
Answer to question
could be many things, but the most is a broken pin in the input of the power supply in the celu, also clean the batery terminal in the celu, and the batery it self, did you check the power supply?..good luck
