20 Most Recent
Adobe Acrobat 6.0 Professional for PC Questions & Answers
How do I edit text on a pdf file?
With Acrobat 6 Professional -Select Tools > Advanced Editing > TouchUp Text Tool
Next, click on the text line where you want to do an edit.
Click-drag to select a string of characters and let your fingers walk the keyboard.
Or, just start where you've placed the cursor.
You'll find it somewhat awkward. PDF is not a word editing/processing
format. If desired edits are few and simple the TouchUp Text Tool
will suffice. If the desired edits are more than you really want to return
to the authoring application (word processor, whatever) to make the edits.
Then produce a new output PDF.
Note that the above presumes the PDF does not have security applied that prevents such edits.
I can't convert file
Just do file > export > image > jpg as in the image bellow:
Or this link might help: http://www.makeuseof.com/tag/6-ways-to-convert-a-pdf-file-to-a-jpg-image/
Trying to remove a watermark from PDF Document
Under the menu in Document, then look for the feature Watermark. Once there it should give you the option to remove. If not then you need to have the original sender re-send the finalized version.
How to uninstall Adobe Reader 8.4.1 from Windows
After going down the route of Start - Control Panel - Program Updates - Highlight the application and click, then select Delete / Uninstall applications and deleting - if that does not work completely then get a free 30 eval of Ashampoo from www.ashampoo.de and use this to clean your system of all the junk and also clean the registry as many applications will leave entries in there even though they are not being used thereby slowing down and potentially causing application and driver conflicts.
Adobe Flash Player
If you want to download flash player you can use the links below to download flash player:
Flash Player 10,0,12,36 Active X (for Internet explorer)
http://tinyurl.com/67twte
Flash Player 10,0,12,36 Plug-In (for Firefox,Netscape,Safari,Chrome,etc)
http://tinyurl.com/8nz9s
Creating pdf from word doc
have you tried other things like notepad? i personally use a program call primo it converts it just like sending it to a printer
http://www.primopdf.com/
Creating a Responses
The simplest way is to go to the bottom left corner of the screen when the document is open, click on the comment button and place your response there. You can also use sticky notes. This works for more recent versions than 6.0 as well.
Cannot Create PDF from Word Document Using Adobe Professional 6.0
You can try to create PDF file directly from Microsoft Word. Adobe Acrobat Professional installs a virtual printer on your computer. Print the document from Microsoft Word, but make sure you select appropriate printer from the list. It should be called "Adobe Acrobat PDF Printer", or similar.
I installed adobe 6 professional a few days ago on
I am not 100% certain but I am not sure you can use that old a Adobe version with Win 7. The current Adobe Pro for creating .pdf files is now version 9 for Win 7. That may be part of your problem. Consult the Adobe website and see if that older version will even run in Win 7
How do I know if
First
go to my computer then double click the C drive and go to program files.
Afterwards look for the folder named Adobe then double click it. Inside the
Adobe folder will be folders specifying your Adobe
products which you have installed.
I INSTALLED ACCORBAT PROFESSIONAL 6 TODAY BUT NOT
This could depend on the operating system you are using. If you are using Windows Vista or 7 then you will have to right click on the progam and click Run as administrator.
Hope this helped,
Detailedhelp
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
