20 Most Recent
Adobe InDesign CS2 Questions & Answers
Error code:0 i cant save any work on InDesign
You are either:
1. Using symbols like "/" in the filename
2. Or doing what I was doing which was trying to save the file in an (accidentally) locked folder. To fix this - right click on the folder and get info - open up sharing and permissions and make sure that your username has full read write access. I also clicked on the settings cog button and applied this setting to everything in the contents of the folder. The folder had somehow corrupted during a network transfer and this is what was making inDesign not play ball.
Hi i have the serial
You can try this link if you want, although I have not confirmed yet myself whether this download page is still working properly:
http://adobe-indesign.brothersoft.com/adobe-indesigncs2-4.0
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Then just click on the blue DOWNLOAD ADOBE INDESIGN CS2 - 4.0 button about halfway down the page, and then follow the onscreen instructions to download and install it. You will need your product key serial number to activate it.
Good luck.
Cs2
this is the keygen serial no try any both
1045-1088-8138-2645-9766-2062
or
1131-1418-7360-0478-2074-7349
Adobe InDesign CS2 serial number invalid
You may have purchased a pirated copy of the software. You need to contact Adobe, and they will help you to determine the validity of your software purchase, and get you a new serial number or re-activate your current one.
If you go to Adobe Customer Support:
CLICK HERE
... you can select the pop-up which offers Live Chat Support. They are very thorough and very helpful.
Installing CS3 upgrade
You need to call Adobe. I have had this problem several times, especially with upgrades. Their product activation call center will walk you through the process.
Hope this helps!
The pages in my booklet don't line up correctly---ahh help!!
Check the X coodinates in the upper left corner and make sure the art is placed or drawn to the guides or edges. A little more infomation would be extremely helpful.
Another thing to do is turn on the Overprint Preview. This is in the View menu. When you turn this on, you see how exactly things are placed/lining up instead of a low rez screen preview.
Are you converting a Publisher file to InDesign? If so, you will HAVE to fix this. Not an exact science. Even with the Utility, they are 2 totally different apps. InDesign will do it's best to maintain the look of the Publisher file, but Publisher was not created for high-end output, it has gotten better over the years... but it is still THE most problematic software for Printing.
Serial number
j225854e,
I had the same thing happen to me on my laptop the harddrive died and I had to reinstall the CS software again, download the CS to CS2 compatability patch from Adobe, InDesign has several others run them and then restart it should work the link to the wWindows download area is:
http://www.adobe.com/support/downloads/product.jsp?product=31&platform=Windows sorry I didn't ask if you were using Mac - I do both so I'll usually ask or cross reference.
randy320sgi
Serial number
Have you ever registered your software on adobe's website? Generally, with adobe products, you can log in and pull out your information and updates, etc. Have you been able to do this?
First timer-need the serial number/key for CS Indesign
None of the keys are the same. You have the key somewhere, if this is new software. It may be on your installation disc or on the folder it was in or in the front of the installation booklet. If you can not find it you need to contact Adobe and have your receipt/serial number etc. handy.
