I found that ZoneAlarm was inadvertently blocking it. I had to completely uninstall the service and then reinstall the latest version again. Now everything is working just as it should.
It sounds like you need to do a repair to the installation of Illustrator. If you need help in doing that, we'll need to know what operating system you're using. In the mean time, you might be able to delete files by booting Windows into 'Safe Mode'
Select the type object (the Select tool must be used, not the type tool); then from the menu, choose: "Type," then, "Create Outlines." The text will become an object, with multiple lines and curves, fully editable, by each point or line.
Chances are you have chosen 'stroke' color as 'blank/empty' in the first pie chart, and 'stroke' color as 'black' in subsequent charts, by mistake. So as a result the charts are having a black outline. You simply have to select 'stroke' or 'outline' color as blank as you did in the first chart. Colors can be chosen in the 'swatches' palette, either for 'fill' or 'stroke' or both. Hope this solves the problem.
am pascal Mbarubukeye as seen on my profile, i would like to ask for supporting me to offer serisl number of adobe audition 1.5, because what i have was corrupted. please help me i begg!
Adobe Communityhttps://community.adobe.com > ... > Discussions
Dec 7, 2018 - Solved: I've had to reinstall all applications after restoring Win10, and I have my CS2 Standard disks; installation itself went fine.
11 answers · Top answer: See here and use the new serial number you will be provided : Download Adobe Acrobat 7 and ...
You should never post such codes on an open forum, others may use it against your wishes. If you call Adobe, they will straighten out the issue for you if your codes are legitimately paid for.
