20 Most Recent
Infinity PS210 Subwoofer Questions & Answers
Infinity PS210 crackling noise instead of bass
Have you tried checking the sub cable? or swaping with another sub to make sure its a sub problem. Sometimes its the amp or the cable between. Im sure you tried this stuff already . Good luck
My infinity ps210 stops putting out any bass. It
Hey. I have two PS210's One popped and stopped working 9 months in to it. Under warranty the technician said that Infinity produced these speakers wit ha known heat related problem. Some part burns up. He replaces them all the time. You can expect about a year's service as my seconf one just popped and died. It costs about $153 to fix it here in phoenix. Will never buy Infinity again from what I know
My fairly new and lightly used PS210 Inf.
for first check out if all the connections are connected properly.so remove all the external wires connected to the unit and then reconnect all the wires again and check out.if the problem is still there then its the circuit board problem.
in the unit there is circuit board.on that circuit board there are number of tiny electronic components.the components are IC, capacitor,transistors ,etc etc .if any of this components gets loose,leaked or faulty ,or its got burned out.then due to this a same type of noise comes out from the unit.checking that component and replacing that component helps to solve this problem.normally this components are not very costly.but as you mentioned that the unit is under warranty.then its advisable to get it repaired or replaced by the company itself because if you yourself get it repaired then this will void the warranty.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
My Infinity SSW-210 Servo Subwoofer quit working yesterday. The light is on and the fuse is okay but there is no sound coming out. Does the sub have another fuse inside?
Unlikely, but open it up and take a look. Some help here.
Rebuild Infinity SSW-210 Subwoofer - AudioKarma
https://audiokarma.org > ... > Speakers
Jan 27, 2021 - One thing to be aware of is that the SSW-210 is a (sort of) servo subwoofer, which you won't be able to replicate. I have one working and one ...
Infinity SSW-210 question - Audiokarma
Oct 9, 2018
The design theory behind Infinity's "servo" subwoofers?
Nov 3, 2017
Vintage Infinity Servo Subwoofer vs modern - AudioKarma
Dec 23, 2015
SSW-210 Servo Subwoofer question - Forums - AudioKarma
Jan 22, 2009
More results from audiokarma.org
Info on Infinity SSW 210 Subwoofer?? - ecoustics.com
https://www.ecoustics.com > forum > home-audio
Oct 21, 2002 - Does anyone have any information on this great powered sub? Infinity SSW-210? (SERVO SUBWOOFER WITH 2 10" DRIVERS) I'm having no luck ...
10 posts ยท In the the early to mid 90's Infinity made the SSW-210 and the SSW-212 ( 250 and 300 ...
Infinity Servo Subwoofer How to? ' AVS Forum
https://www.avsforum.com > threads > infinity-servo-su...
Dec 26, 2009 - I picked up an Infinity Servo Subwoofer yesterday, but not quite sure as to how to ... The SSW-210 or SSW-212 have two drivers and no port.
Infinity tss 750 sub-woofer when powered on immediately pulls speaker in and has loud humming. no inputs hooked up, only plugged in to ac power source.
The loud humming is the sound of AC mains - clearly your amplifier is receiving an input from somewhere and possibly into the front end.
The hum could be induced by radiated energy from nearby unshielded equipment, it could be the result of an accidental hum-loop or could be because the amplifier power supply has a fault.
It is usual practice with amplifier construction to ensure unused inputs are shorted to ground by switching or by additional contacts and wiring at the input sockets. High gain high impedance inputs can cause a great deal of unwanted noise if they are not shorted.
I suggest you read the instruction manual and perhaps Google a few hints and tips about amplifiers and stuff.
