20 Most Recent
Diamond Multimedia ( VC500) Video Capture Questions & Answers
Help Me remove lag please
Maybe you need to switch to another video recording software instead.
Smartpixel might be a good choice for you, it is compatible with all the PC games, and it has a PIC in PIC mode which allows you comment on the webcam while game capturing, it is simple and easy.
5/7/2020 2:20:31 AM •
Diamond...
Answered
on May 07, 2020
When I capture old VCR
Somehow, you have made your System Audio Output {Jack} the Primary source of the System's Audio. You are using Digital & Analog Audio at the same time. In Modern Electronics, you have to make one or the other the ONLY source of the System sound! I wish I could see your Set-Up because I know I'd spot the problem instantly. Your solution is most likely reading Your User's Guide very carefully, and finding the Switch Setting that is designed to make it work properly. This should not be happening -- most likely you just have a Function Set incorrectly.
2/3/2018 6:38:49 AM •
Diamond...
Answered
on Feb 03, 2018
VC500 - windows 7 - video shows up fine until
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
5/19/2017 2:19:44 PM •
Diamond...
Answered
on May 19, 2017
Not capturing all the video
Video capture is cpu intensive and you do not want the computer to be distracted in any way during the process lest you incur errors.
4/9/2017 1:36:04 AM •
Diamond...
Answered
on Apr 09, 2017
