20 Most Recent
Adobe PageMaker 7.0 for PC Questions & Answers
Importing eps file without white box outlining
Sometimes, this has something to do with the original native logo file creation itself. For instance, if the image was created in Illustrator or Photoshop, and there are a number of layers, sometimes, they pop up in the EPS.
Solve bad table index linking
do have any backup version or another " a bit older" dump ?
you can retrieve the table in a read only status first and then try to link a copy of it,
also you can check the languages option and the application " SQL / Orcle.. "
version before working with the tables.
How to use latha tami font in page maker
In that case please let us know the Windows OS you are using and version of Page Maker too.
If you have OTF/TTF type font, U can put here 'C:\Windows\fonts\'
If you have Type1 font, U can put here C:\Program Files\Adobe\Adobe PageMaker 7.0\Fonts\
To manually install
1.Click Start, and then click Run.
2.Type %windir%\fonts, and then click OK.
3.On the File menu, click Install New Font.
4.Click the font you want to add. To select more than one font at a time, press and hold down the CTRL key while you click each font.
5.Click to select the Copy Fonts To Fonts Folder check box. The Windows\Fonts folder is where the fonts that are included with Windows are stored.
6.Click OK.
I can not use unicode font in my lamguage with page maker
Sir,
I use Adobe page maker 7.0, I collected some documents from website. All that documents are Arial Unicode MS. I cannot edit the scripts in Page make, I copy the document and paste in the page maker, but all letter convert to other font, so please tell me how can edit the documents in same fonts in page maker.
Solution for adobe pagemaker 7.0 spell checking problem
For those running Windows Vista, you can enable spell checking in Pagemaker 7 by simply turning off the user account control. This control is what pops up every time you attempt to run a program windows Vista isn't familiar with, asking if you really want to run it.
To turn it off, go to Control Panal, select user accounts and forms, select User Account Control, and in the follow up screen delete the checkmark.
Of course, the account control is there to protect you against unauthorized running of spyware and such. Be sure you have good virus protection!
I con't type Tunga (Kannada)
go control panel, click on keyboard , select language and make it default
save and exit , then wherever you type it will be in that language
Adobe acrobat distriller 3.0
SYSTEM REQUIREMENTS
Perl 4 or later installed on any of the following systems:
IBM AIX 4.2 or 4.3 with IBM?s Y2K patch installed
HP UNIX 10.x or 11.x with HP?s Y2K patch installed
Sun 5.4/Solaris 2.4 with Sun?s Y2K patch installed
Sun 5.5/Solaris 2.5 with Sun?s Y2K patch installed
Sun 5.6/Solaris 2.6 with Sun?s Y2K patch installed
Sun 5.7/Solaris 2.7
18 MB of hard disk space for Acrobat Distiller
32 MB RAM
INSTALLATION INSTRUCTIONS
The Acrobat Distiller 3.02 for UNIX Y2K Patch consists of two files:
-the distill file, which is the Distiller startup script.
-the distill.y2kfix.pl file, which is a Perl script that is invoked by the Distiller startup script.
To install the Acrobat Distiller 3.0.2 Y2K Update:
1.Make a backup copy of the distill file, which is located in the Distiller 3.02 installation directory. For example: cp distill distill.bak
2.Copy the distill file and the distill.y2kfix.pl file included in the archive to the Distiller 3.02 installation directory.
3.Make sure that the distill.y2kfix.pl file has execute permissions. For example:
chmod a+x distill.y2kfix.pl
4.Modify line 1 of the distill.y2kfix.pl file so that it contains the pathname to the Perl interpreter installed on your system.
5.Modify line 16 of the distill file so that the "install_dir" contains the pathname to the Acrobat Distiller 3.02 installation directory.
