20 Most Recent
Nintendo 3ds Xl blue/black Questions & Answers
How do I connect a nintendo 3DS-xl to home wifi internet?
You can just go to the settings on the ds and network settings then setup a new connection and find your WiFi name then connect using the password you have chosen or on the bottom of your router/modem no cables required
10/22/2017 10:40:16 AM •
Nintendo...
Answered
on Oct 22, 2017
Ssid
SSID is a public name of your wireless network due to which you are able to connect to any particular network.
051099
verifiy ssid/wep wireless settings either from the router or your internet provider
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
- Create a new connection: This error can occur if a setting (like your network's name) has changed since you last connected. If it's been awhile since you connected, or if this is your first time connecting, creating a new connection file will often resolve this error code. Click the button below for your system and we'll walk you through the connection step-by-step
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099&system=DS&locale=en_US
How do I set my
To find the SSID, you can always just turn on the wireless on a laptop and see which network your home network is. If that's not available, you can connect to the router via an ethernet connection and visit the router setup page (usually 192.168.1.1 or something like that), put in your username and password (typically admin/admin or admin/(no password) or admin/password) and view the wireless settings to see the SSID.
According to the wii information page (located
here), there could be several issues. Double check your SSID to be certain, also check
this page to see if your router is known to be compatible.
7/20/2011 5:29:22 PM •
Nintendo...
Answered
on Jul 20, 2011
I want to know how
Howdy. you need the free CD from netflix to make the streaming feature work on a Wii. Once the FREE CD is inserted, it will take you through the very short, easy set up step by step on your screen. My favorite way to watch movies at home:)
I want internet on my
Hi!
I saw a video in youtube that can actually guide you connect a Nintendo DS to the internet. Please click on the link below:
http://www.youtube.com/watch?v=xY22kVkh0J8
Hope this helps.
5/3/2011 8:33:17 AM •
Nintendo...
Answered
on May 03, 2011
Describe your Nintendo Probleml
Wireless keyboards will only work with Wii of it has a 'USB Wireless Receiver' (also called a dongle) which plugs into the back of the Wii. So make sure that is plugged into the Wii USB port at the back.
Although the Wii uses bluetooth for the Wii Remotes, you cannot use bluetooth for keyboards.
ALSO... the Wii USB ports are only USB1 (Not USB2). Therefore some fancier keyboards may not work if they require USB2.
3/13/2011 9:29:27 PM •
Nintendo...
Answered
on Mar 13, 2011
I just got a DSI
You have to have a wireless network already set up in order to connect to the internet from you DSi. So you'd need a wireless router or you can use one of the many USB wireless adapters out there.
2/28/2011 1:25:23 AM •
Nintendo...
Answered
on Feb 28, 2011
