20 Most Recent Lenovo IdeaPad Z580 215129U 15.6" Windows 7 Home Premium 64-Bit Questions & Answers
Cant open any thing from desktop to internet
Do a system restore choose a date to before this started. Terry
4/3/2014 10:44:30 AM • Lenovo IdeaPad... • Answered on Apr 03, 2014
Computer wont stop timing out
Whether you use your computer for home or for work, it is important that it be available when you need it. If your computer keeps timing out, it will take precious time to bring it back to life so you can use it. Fortunately there are some simple changes computer owners can make to keep their computers from timing out and going into sleep mode. Log on to your computer and click on the "Start" button. Choose "Control Panel" from the menu. Double-click on the "Power" icon in your computer's control panel. Look at the power settings for each option. Adjust the power options so that the computer's hard drive, monitor and system resources do not turn off. Many computers are set to time out after a period of inactivity, but it can be time consuming to wake them from their hibernation. By changing the power options you can prevent your PC from timing out and make sure it will be there when you need it. Hope this helps.
12/19/2012 7:22:19 PM • Lenovo IdeaPad... • Answered on Dec 19, 2012
Lenovo youCam is not openning
it's a real problem.Drivers are programs or files that contain sets of instructions for the operating system detailing how best to operate or drive a certain piece of hardware. Youcam is a driver.When you notice poor performance from a component it is time to upgrade your drivers.But how?Here it comes:
You can find the latest downloads and drivers for your system using the following options:
Option 1: ThinkVantage System Update (TVSU)
Note: This is only for Think productsIf you are using Think products, you can choose to download your drivers automatically using the TVSU.
Option 2: Driver Matrix.To find information on your Lenovo product, please perform the following steps:
  1. Go to Lenovo Support
  2. Click on the respective THINK product button, for example: ThinkPad.
  3. Click on your product name, for example: T410. You should then see the Driver Matrix for your product.
  4. If your product is non-THINK notebooks, please perform the following steps:
    1. Click on the "ThinkPad" button.
    2. Click on "Most common files for Value Line notebooks".
    3. Look for your system here, for example "N500".
Option 3: Driver download listing.
  2. Keyin your product number using the "QuickPath" option.
    1. Product Number (ie. 1234-XYZ)For more details, please refer to Find My Product NumberYour Lenovo product number should be either 7 / 10 alphanumeric characters.
    2. Product name (ie t60, w510, y500 or n500).
  3. Click on "Find My Product" button.
  4. Click on your product name.
  5. Click on "Download Drivers & Software" link. You will see your drivers arranged in categories.
  6. Expand the related category and download your driver.
Hope it is helpful.please rate me.
10/24/2012 3:52:50 PM • Lenovo IdeaPad... • Answered on Oct 24, 2012
Lenovo Y550P stopped charging battery
Check the Power Adapter and Outlet: Ensure that the AC power adapter is securely connected to both your laptop and a functional power outlet. If your laptop has an AC power indicator light, make sure it's illuminated. If not, try a different wall outlet (avoid using a power bar) . Battery Charge Stops at 60%: If your battery charge stops at 55%-60% and shows a "plugged in, not charging" message, it might be due to a power management setting. Some Lenovo laptops have a feature that limits battery charging to extend battery life. To disable this: For models with Lenovo Energy Management, Lenovo Power Manager, OneKey Optimizer, Lenovo Settings, or Lenovo Vantage: Check if "Conservation Mode" is turned on. If so, turn it off. If the issue persists, try updating your laptop's BIOS: Go to the Lenovo support website, download the latest BIOS for your model, and install it. Reboot your PC and check if the problem is resolved. Hard Reset: Sometimes a hard reset can help resolve charging issues: Shut down your computer. Remove the battery (if detachable). Hold down the power button for 30 seconds (with the battery removed). Reattach the battery, plug in the AC adapter, and turn on the computer. The battery should start charging . If these steps don't solve the problem, there might be other causes.
4/1/2024 3:48:51 PM • Lenovo Computers... • Answered on Apr 01, 2024
I am using lenovo y510p gaming series laptop, when I try to play RDR2 game. It gives error that your drivers need to be updated.
In that case I would go onto the Lenovo web site and update the drivers. Never download drivers from other sources!
3/27/2024 4:44:19 PM • Lenovo Computers... • Answered on Mar 27, 2024
2answers
How to connect an onn wireless mouse to a lenovo chromebook? i tried doing this 3 times and still wont connect.
Firstly, try turning over your Bluetooth mouse and find the power switch. Make sure it's turned to ON. You should see the optical light turn on (usually red). Place the mouse back flat on your mouse pad. On your Chromebook, select the lower right corner of the taskbar. In the window that pops up, select the Bluetooth icon. If the Bluetooth status is currently off, enable the toggle switch to enable Bluetooth. Once enabled, you'll see a scanning status as your Chromebook looks for active, nearby Bluetooth devices. When your wireless mouse appears, you can select it to pair and connect to it. Once your Chromebook has made its connection with your Bluetooth wireless mouse, you'll notice the mouse pointer moving when you move your mouse
2/19/2024 8:12:43 PM • Lenovo Computers... • Answered on Feb 19, 2024
How to fix slot has been permanently lock lenovo s90-a
how to remove sim slot permanently lock in lenovo s90-a
11/26/2023 11:35:16 AM • Lenovo Computers... • Answered on Nov 26, 2023
Lenovo ThinkPad L510 boot menu disabled
Repeatedly tap the F1 key when the Lenovo, ThinkPad, ThinkStation, or ThinkCentre logo appears, The computer may beep once to indicate that it will boot to BIOS. How to Enable Boot device List F12 Option The following example shows a system that has an option to enable or disable the Boot device List F12 Option. Go into the BIOS to enable Boot device List F12 Option (option is usually under the Startup tab).
11/25/2023 6:18:45 AM • Lenovo Computers... • Answered on Nov 25, 2023
2answers
How do I take a screenshot with Lenovo SK-8821 keyboard?
It is very simple. Just press window key and then press PrintScreen key simultaneously. OR you just press PrintScreen key And then open paint Then press ctrl+v it will paste your screenshot. and then save it.
11/18/2023 6:00:48 PM • Lenovo Computers... • Answered on Nov 18, 2023
How to remove keypad from Lenovo thinkpad
Removal steps of keyboardLoosen the screw to the unlocked position to unlock the keyboard frame. Turn over the computer. To reveal the screw heads beneath the frame, use the flat-head screwdriver to slide the keyboard forward by 2.5 mm (0.1 inch). Use the cross-head screwdriver to loosen the screws.
Removal and installation steps for keyboard - ThinkPad T470s
11/5/2023 12:30:23 AM • Lenovo Computers... • Answered on Nov 05, 2023
3answers
Can we undo window 7 anytime upgrade
no once you have upgraded, it cannot be degraded to the previous version. and do you think this will solve the issue? you had the same problem even before with windows 7 home basic genuine version,then how could you think about this problem.let me tell you that genuine or piracy version of windows does not harm the machine but it is *********** board which is creating problem.this symptom "sudden shutdown" suggests that you need to change *********** board if it is not repairable.
7/29/2023 6:22:17 PM • Lenovo Computers... • Answered on Jul 29, 2023
Refurbished Lenovo w/MS Office 365 stuck in loop.
This commonly happens with pirated software. Remove Office 365 and try a fresh install.
7/13/2023 6:45:50 AM • Lenovo Computers... • Answered on Jul 13, 2023
Lenovo ThinkVision monitor T27h-2L not working with my Thinkpad P50 laptop. Monitor not detected. Just goes into Standby mode.
There could be several reasons why the Lenovo ThinkVision monitor T27h-2L is not working with the Thinkpad P50 laptop. Here are some possible solutions: 1. Check the connections: Make sure that the USB-C cable is properly connected to both the laptop and the monitor. Try using a different USB-C cable to see if that resolves the issue. Also, check if the USB-C port on your laptop is functioning properly. 2. Update drivers: Ensure that you have installed the latest drivers for both your laptop and monitor. You can download the latest drivers from Lenovo's website. 3. Change display settings: Sometimes, changing the display settings can help resolve issues with external monitors. Go to "Display Settings" on your laptop and select "Extend desktop" or "Duplicate desktop" to see if that helps. 4. Reset monitor settings: If none of the above solutions work, try resetting your monitor to its default settings. To do this, press the "Menu" button on your monitor and navigate to "Factory Reset." If none of these solutions work, it's possible that there may be a hardware issue with either your laptop or monitor. In this case, you may need to contact Lenovo support for further assistance.
6/21/2023 8:17:32 PM • Lenovo Computers... • Answered on Jun 21, 2023
2answers
How do I factory reset my Lenovo think pad it doesn't have novo key
If your Lenovo ThinkPad doesn't have a Novo key, you can still perform a factory reset using the Windows installation media. However, please note that this process will erase all data on your computer, so make sure you have backed up any important files before proceeding. Here are the steps: Create a Windows installation media (USB or DVD) using another computer. You can download the Windows installation files from the Microsoft website and use the Windows Media Creation Tool to create the installation media. Insert the Windows installation media into your Lenovo ThinkPad and restart the computer. Press the F12 key repeatedly to enter the boot menu. Select the Windows installation media and press Enter. Follow the on-screen instructions to install Windows. When you reach the "Where do you want to install Windows?" screen, select the partition that contains the current Windows installation and click "Delete." This will erase all data on the partition. Continue with the Windows installation process until it completes. When prompted, set up a new user account and password. Once Windows has finished installing, make sure to install all necessary drivers and software for your Lenovo ThinkPad. Note: If you don't have a valid Windows license key, you will need to purchase one before performing the factory reset.
4/10/2023 8:47:26 PM • Lenovo Computers... • Answered on Apr 10, 2023
User Profile Service service failed after factory reset and unable to access troubleshoot services: Windows 10
It seems that your computer is stuck in a boot loop and you are unable to access the troubleshoot services. Here are some steps you can try to resolve the issue:
  1. Disconnect all external devices from your computer, except for the keyboard and mouse, and restart the computer.
  2. If that does not work, try to access the Advanced Startup Options by holding down the shift key while clicking on the Restart option in the Start menu.
  3. If you are unable to access the Advanced Startup Options, you can try to create a Windows 10 installation media on a USB drive using another computer and then boot your computer from the USB drive.
  4. Once you are able to access the Advanced Startup Options, you can try using the Startup Repair tool to fix any issues with the boot process.
  5. If that does not work, you can try using the System Restore tool to restore your computer to an earlier point in time when it was working properly.
  6. If none of these steps work, you may need to consider reinstalling Windows on your computer.
It is also possible that there is a hardware issue causing the problem, in which case you may need to take your computer to a professional for repair.
3/18/2023 6:46:05 PM • Lenovo Computers... • Answered on Mar 18, 2023
3answers
2answers
How to factory reset an E560 lenovo thinkpad
ck this out hope it helps. https://www.youtube.com/watch?v=j7G93cWDVqo
2/24/2023 2:20:21 PM • Lenovo Computers... • Answered on Feb 24, 2023
5answers
Outlook express error 0x800cc0d
Checkout this cost effective and result oriented Outlook Express Repair software, with the help of this utility user can easily restore emails files & folders in just few clicks.http://www.recoverfilesdata.com/outlook-express-dbx-recovery.htmlDownload the free trial version to get results.
1/19/2023 7:28:08 PM • Lenovo Computers... • Answered on Jan 19, 2023
Computer is doing something ive never experienced
There could be several reasons why your screen is freezing and the audio is cutting out while playing games. Some possible causes include:
  • Overheating: Make sure that your computer is properly ventilated and that the internal temperature is not too high. Clean the dust inside the computer and check if the fans are working properly.
  • Driver issues: Make sure that the graphics card and sound card drivers are up to date, and that they are compatible with the games you are playing.
  • Power supply: Make sure that your power supply unit is providing enough power to your computer.
  • Memory issues: Make sure that you have enough RAM, and that it is properly seated.
  • Virus or malware: Perform a full scan of your computer to check for any viruses or malware that may be causing the problem.
  • Hard disk: Check the health of your hard drive using diagnostic tools and make sure it's not failing.
  • Overclocking: If you have overclocked your PC, try to revert the clock speeds to default.
It's difficult to say exactly what the problem is without more information, but by checking these possible causes, you may be able to identify and fix the issue. If the problem persists, it would be best to contact the manufacturer's technical support for further assistance.
1/12/2023 12:24:32 PM • Lenovo Computers... • Answered on Jan 12, 2023
Lenovo IdeaPad Z580 215129U 15.6" Windows 7 Home Premium 64-Bit Logo
Popular Tags
5 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
computer wont stop timing out
  • Computers & Internet
