If you mean that smoke is coming from the equipment, it's time to unplug it and get it serviced. This typically means that a component has failed - it can usually be identified because it will be physically deformed. You might see a crack in an IC, a burned resistor, or something similar. Often, though not always, the component that failed may not be the only defective component on the board - for example, a voltage regulator may fail, but it might be due to a faulty capacitor, or some other short-circuit on the board. It's best to refer the repair to someone who is skilled in troubleshooting.
To remove the front panel of the Behringer Europower PMP1280S, you may need to follow these steps:
1. Ensure the device is powered off and disconnected from any power source.
2. Locate all the screws that secure the front panel to the chassis. Based on your description, it seems you have already removed the screws on the front side and the ones on the frame.
3. Sometimes, there may be additional screws hidden beneath labels or rubber feet. Carefully inspect the front panel for any hidden screws and remove them if present.
4. Once all the screws are removed, gently try to pull the front panel away from the chassis. It might be snug due to connectors or clips holding it in place.
5. If the panel still appears to be stuck in the middle, double-check for any screws that may have been missed or hidden. Make sure you have removed all the necessary screws to fully release the front panel.
6. If the front panel remains stuck, do not force it as it could potentially damage the device. Instead, consider consulting the user manual or contacting Behringer customer support for specific instructions or further assistance.
Remember to exercise caution when working with electronic equipment and always refer to the manufacturer's instructions or seek professional assistance if you are unsure.
the green light is power indicator not mic level. the green light should come on when powered up. remove mike cable and the see if green light comes on, If it does power down and connect mike and cable (hopefully you have a good quality one and not a toy)
Call Behringercustomer service. Where did you buy it from, if new it is under warranty and need to replaced with another new one. It is not an audio mixer the yellow and right lights are for clipping.
Install all necessary audio drivers on your PC.
Connect the unit to AC power.
Connect the unit to your pc via either USB 2.0 or firewire serial bus.
Press and hold the DIGITAL SELECT button while powering the unit on to switch the bus mode from firewire to usb and vice versa.
Question translated to English
Solo hablamos ingl?s en el sitio web norteamericano. Lamentablemente no tenemos idea de qui?n es este conductor de invierno. Por favor danos m?s informaci?n para ayudarte mejor. Es un problema de seguro de autom?vil, debe comunicarse directamente con la compa??a de seguros.
ENGLISH@
We only speak English on the North American website. Unfortunately we have no idea who this winter driver is. Please give us some more information to help you better. It is is a car insurance issue, you need to contact the insurance company direct.
DICEUS with 13 years experience.
SIMFORM for modernizing legacy architecture.
ColorWhistle for leads.
PixelCrayons for tailoring to your specific needs.
