20 Most Recent
Brother SE-400 Sewing & Embroidery Machine Questions & Answers
When i push my foot pedal on my Brother SE 400 machine shakes and goes into safe mode
TRY TO REMOVE YOUR BOBBIN CARRIER AND NEEDLE AND SEE IF THE MACHINE WILL MOVE SMOOTHLY WITHOUT THEM. IF IT IS RUNNING SMOOTHLY YOU KNOW YOUR PROBLEM IS THE BOBBIN CARRIER OR NEEDLE. YOU MUST HAVE THE RIGHT SIZE BOBBIN. ONCE YOU HAVE THE RIGHT BOBBIN YOU CAN PLACE ONE DROP OF OIL ON THE RACE (LITTLE TRACK UNDER BOBBIN CARRIER) AND PUT THE CARRIER IN. WITH YOUR HAND TURN THE HAND WHEEL TO SEE IF IT IS INSERTED PROPERLY SO IT ROTATES SMOOTHLY. THEY'RE IS A PLACE THAT KEEPS THE CARRIER FROM MOVING. YOU MUST BE CAREFUL TO LEAVE IT LOOSE SO THREAD CAN GO UNDER IT. IF IT IS STILL MOVING SMOOTH WITH YOUR HAND YOU CAN TRY THE PEDAL. IT SHOULD WORK. NOW, REPLACE THE BOBBIN MAKING SURE IT IS ROTATING THE RIGHT DIRECTION. I CAN'T STRESS ENOUGH TO MAKE SURE THE BOBBIN IS THE RIGHT SIZE. IF THIS IS OK THEN REPLACE YOUR NEEDLE. THE NEXT STEP IS TO GO TO YOUR REPAIRMAN IF IT IS STILL A PROBLEM.
My brother exedra e-40 #db2-b737-413
- In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
