20 Most Recent
Gyration Ultra Cordless Optical Mouse Questions & Answers
GP4101 Powere Supplay
The Ultra AC Adapter has the following output specification.
Rated Output Voltage - 9 Volts DC at 200 Milliamps to 1.3 Amp Max
Center of pin Positive
Pin Size
Length - 9.5 mm
Width - 5.5 mm
Center Hole - 2.1 mm
Nothing yet
make sure the battery is good ((has full charge)) make sure the usb device for the mouse is inserted correctly into the usb port (if applicable) if this fails to fix the problem you could try it in safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click to update driver
if your computer came with a motherboard disk the driver could be on it
hope this helps you
