20 Most Recent
Meridian Two-Line Corded Business phone Questions & Answers
Some one has changed the pass code on my phone
You could try to reset the passcode by pressing feature 983
the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys. press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
your password will be reset to 0000
press the next key till you see the ext/name info.(about the second or third "next"
press the CHNG key and enter in your first and last name
the # key advances you one space press it twice to enter in the comma between the first and last name.
press the Rls key when finished
9/8/2010 10:03:00 AM •
Meridian...
Answered
on Sep 08, 2010
Meridian 9516 loses directory after
Hi.
This phones use an internal coin shaped or on-board soldered battery. If the phone loses data and programming each time there is a power surge, than the battery is gone. In that case it may be time to replace the phone.
8/13/2010 2:53:27 PM •
Meridian...
Answered
on Aug 13, 2010
Cannot dial out on my Meridian 9516 telephone
Is the Program button on . If it is turn it off. You can also try resetting the phone by unplugging the silver line cord from the phone or the wall jack and then replugging it after about 10 seconds.
see if that works
9/3/2009 3:36:28 PM •
Meridian...
Answered
on Sep 03, 2009
Changing Ring Tones
If you're using Nokia fone, go to Contact through the menu and select Caller group. There you'll be able to customize groups for your user. Select a group and customize/edit it.
1/21/2009 8:54:10 PM •
Meridian...
Answered
on Jan 21, 2009
CALL TRANSFER
Go to Settings from the menu options. Select it, then select Call settings. From call settings, select call transfer or divert call. There, you will be able to activate call transfer to a specified number.
8/21/2008 4:41:44 PM •
Meridian...
Answered
on Aug 21, 2008
I've got on old meridian phone system in our
Haha they are old! Enter programming by dialing Feature **266344, then using 266344 as your password. Your password may be different depending on your phone company. Contact them for more details. Scroll using navigation keys to "General Admin". Scroll to Time and Date, then select time. You can go through individually and fix the hour and minute. When you are done, press Rls
