20 Most Recent
SonicWALL PRO 2040 (01-ssc-5703) Firewall Questions & Answers
Cisco vpn disconnection through sonicwall firewall
This may sounds obvious but have you forwarded the correct ports through sonicwall for your VPN?If you have, do you have any QoS running, it could be worth checking that VPN has priority over VoIP etc.Do you get disconnects all the time or is it only during busy periods? You may be overloading your server, perhaps it's time for more RAM.
C:/hp/tmp/src/
It seems that particular application(Sonic) files might have got corrupted or not installed properly.
So you can try these steps:
1. Start -> Run -> Type %temp% -> click OK -> delete all the files( if you are not able to delete any files please skip those files)
2. Start -> Start -> Run -> Type temp -> click OK -> delete all the files ( if you are not able to delete any files please skip those files)
2.Click on start -> Run -> msconfig -> click on services tab -> on the same window at the left bottom you could see "hide all microsoft" option, put a check mark for hide all microsoft option and then disable all the services -> go to the startup tab -> right bottom you could see disable all -> click on disable all -> click on apply -> ok -> click on restart on the popup.
/quote
Make sure you put a check mark for "Hide all Microsoft" in the service tab before you disable all the services.
quote/
I had my computer "optimized"
Take it back to Office Depot and dem
and they fix it. They use a canned program that strips out programs they think MIGHT be bad. They have killed Sonic.
If you have your recovery disk it will be needed.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
My dell sonic is missing
I would go to symatec webste, and do a virus scan. You might have a virus that is deleting the files off. You can try going to
www.dell.com enter your computer model number and download the sonic program.
