20 Most Recent
Nintendo Pokemon Emerald for Game Boy Advance Questions & Answers
How to download a game that will surely works
Unfortunately, there's no guaranteed way to ensure that a rom will play, since they are created by gaming hobbyists. In general, downloading your game from a reputable site, like coolrom, can help. Also, you may want to download a few other games to test your emulator. If you have problems running multiple games, you may need to find a better emulator. I hope that helps, good luck!
How to continue pokemon emerald
u can continue the game because i can now go to battle frontier and u can now use the ferry and special pokemon will fill up your national pokedex when u try one of the gyms in battle frontier.
Game wont start maby battery
You may have a deffected game. if you bought the game used, the person before you might have done something to destroy it. game boy advance games are very delecate and freeze frequently if damaged
Steal Pokemon From Battle Frontier
once u r at the factory,choose any level and pick your pokemon.once the guy starts talking,pay close attention.right before you walk in the door quickly tap and hold L and R up some hall and check your
party.if you done it correctly you should end up with those pokemon.
note:the pokemon you give them to hold,they keep.so make sure there crapy.
HOW CAN I PLAY A
All GBA games are playable on pc. For that you need an emulator and the GBA game rom. The best emulator for running GBA games on pc is visual boy advance and you can download it from the following link:
http://www.coolrom.com/emulators/gba/14/Visual_Boy_Advance.php
And you can download the pokemon emerald rom from the following link:
http://www.coolrom.com/roms/gba/14604/Pokemon_Emerald.php
After downloading the emulator and rom, extract it to any folder and run the emulator. Before opening the rom, you need to configure the buttons to play the game.
To do that, goto options->joypad->configure->1 and select the buttons that you want to use and then click Ok.
Then drag and drop the rom file into the emulator, and play.
good luck!!!
Using game shark cheats
i advise you to use The VBA *Visual Boy advance* Beacause it's easy to use gameshark cheats on it
Celebi
Celebi is unobtainable in any Pokemon game.
We cant cant catch deoxys and jirachi
and also if this helps to get
Deoxys g
et the aurara ticket, and go to Birth Island. stock up on lots of Ultra balls 'cuz this can be a tricky Pokemon to catch. Make sure your Pokemon are at least L40 or deoxys will kill em. In order to catch jirachi in emerald the guy in the space center has to say 56 successful launches then you can somehow go catch jirachi.
hope this helps
Ive turned on my pokemon emerald gba game but
first there is no problem of the cheats so don't blame them and solution is that when ur game doesn't don't try rubbing liquid on it as the game will crash because of short circuit my suggest u to go in settings go saved utility copy copy urn saved file and make a folder in your pc and delte the game get a new one and go in saved folder and left click on the folder open with and then choose pokemon emerald and your saved file will work in the game by u will not loose urn save data
