20 Most Recent
Nintendo Pokemon Pearl Version for DS Questions & Answers
How to get rare candies in pokemon Y
Hi there!
You can find rare candies to pickup in Route 13, Route 16, Route 17, Parfum Palace, Ambrette Town, Couriway Town, Victory Road, Lydsandre Labs, Route 18. You can also buy them for 500 pokemiles from the Pokemile Seller in Lumiose City and for 48 BP from the left prize corner of the Battle Maison.
Have a fantastic day!
How do you fill up
actually, there are cheat codes. you just have to get a cheap add on called a AR (action replay) card. it costs about 20$ and you can get it at gamestop. once yoou have it, it should have most of the cheat codes and games already on the card. But if it doesnt have the specific cheat code on the ar card then use thisgo to the rest of the cheatspress add codename the codepress okthen punch in this code- 94000130 fcfb0000b21c4d28 00000000b0000004 00000000e000154c 00000124ffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff f0001fffffffffff ffffffffffffffff ffffffffffffffff ffffffff ffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff ff001fff70000000 0000000000000000 0805000000000000 0000000000000000 0003200000000000 0200000000000000 0800000080000000 0080000020000000 000000807fffffff fffffffcffffffff 7ffff9ffffffffff ffffffffffffffff ffffe7ffffffffff feffffffffffffff efffffffdfffffff fffffffffbffffff 00ffffff00000000 f0f0ffff03020100 070605040b0a0908 0f0e0d0c13121110 171615141b1a1918 00000000d2000000 00000000to activate it press (L+R+Selcect) its ling but it works.... i used to be a huge pokemon fan
Pokemon pearl wont work after using action replay
try to use th action replay walk trough walls cheat to get out it ussally works or if you've already tried this then I am sorry but you may have to delete your game file and start a new one.
If this doesn't help sorry but can you still rate this please. Xamous
Erased Action Replay
Download the code manager if you don't have it. In subscriptions list add this: http://www.freewebs.com/marioforever89/Codes/Link.xml In the NixShadow part there are tons of codes for Pearl so just drag the word "NH's Pokemon Pearl" over when your DS is plugged in.
When the action replay screen comes up i put
Yes.....the same thing happened to me the other day; but I fixed it. Go onto Google and type in "Poke'mon Pearl number for action replay". Then, find the number for it and install the number into your action replay; It's that easy.
Tweaking Glitch on Pokemon Pearl
Hi.
Try to do this not sure if it will 100% work but I'm impress you won't give up easily. Try to keep riding onward until you hear Jubilife City music(which you heard already) in
the background. Now, pop open the menu after that open up any category. Click exit the menu and the graphics should return to normal.
If it doesn't work, try to redo/preplay that step over
from the last pace you have saved it since there's a chance for you not to reset the game over again.
Let me know the outcome.
Where is the storage key?
From the Pok?mon Center in Veilstone City, head down, then go right a slight bit and thenhead north up some stairs to where a Team Galactic Grunt should be standing next
to an antennae. Talk to him, and he will run off, leaving behind the Storage Key
for you. Now head to the Galactic HeadQuarters, which is in the northwest corner
of the city, right next to the entrance to Veilstone City. Head up the stairs
behind the Veilstone department store to go inside.
Its saying that theres not an access point i range
You might have to enter your information manually. That's what I had to do. Make sure you know your SSID (the name of your wifi device -- mine is Overdrive-75E) which you can find on the device itself or in the box it came in. And you'll need your WEP key, which is the password to connect to a secure link. You can also find it in the same location as your SSID. It's generally 8-12 characters long.
I was doing i pokemon
Try turning off some of the codes you were using. Some codes can only be activated one at a time. Also make sure the code isn't corrupted. Usually home-brewed codes are corrupted. Www.codejunkies.com and www.neoseekers.com have a LOT of non-corrupted codes.
It will not except my WEP key
Make sure it's put in properly. Make sure you're even looking at the right string of letters and numbers. It's confusing I know.
