20 Most Recent Xicat Interactive F/A -18 Precision Strike Fighter for Windows Questions & Answers
0answers
How can I get the F/A -18 Precision Strike Fighter keyboard reference guide
Aileron Left Keypad 4 Aileron Right Keypad 6 Elevator Down Keypad 8 Elevator Up Keypad 5 Rudder Left < Rudder Center / Rudder Right >
Increase Thrust = Decrease Thrust - Afterburner Backspace Brake Space Gear G Flap F Hook H Dump Fuel Shift D Refuel Shift F Service (refuel/arm) Shift S Eject Shift E Damage Display D Engine Display E HUD Options ----------- HUD Altimeter Toggle Ctrl A HUD Brightness Ctrl B HUD Clutter Reject Ctrl C NAVIGATION ========== Autopilot Toggle A Autopilot Mode Shift A Waypoint Cycle W TACAN Cycle T ILS Toggle L Moving Map/Scale M Nav./HSI Scale N RADAR ===== AA/AG Toggle R Sub-mode Cycle Q Standby B IFF Interrogate I Range Decrease Tab Range Increase Shift Tab ACM Cycle Shift R AACQ Cycle Shift Q Silent Mode Ctrl R Radar Target ------------ Designate/Cycle \ Undesignate/TDC Stow Shift \ TDC Up Shift Arrow Up TDC Down Shift Arrow Down TDC Left Shift Arrow Left TDC Right Shift Arrow Right Radar Scan Volume ----------------- Decrease Azimuth Z Decrease Elevation X Increase Azimuth Shift Z Increase Elevation Shift X WEAPONS ------- Stores Display S Cycle AA [ Cycle AG ] CCIP/Auto Toggle Shift ] Jettison Station J Release Flare ' Release Chaff ; ECM Toggle C Designate/Release Enter Electro-Optical --------------- E-O Weapon Cycle O E-O Target Cycle Ctrl \ HARM ---- HARM Select U HARM Target Cycle Ctrl \ SIMULATION ========== Pause Flight P Exit Flight Shift Esc Fast-time Toggle Ctrl F Warp-time Toggle Ctrl W Earlier TOD Ctrl E Later TOD Ctrl L Night/Day (+6 hr) Ctrl N Joystick Program Ctrl J Hide Instruments Ctrl I RADIO MESSAGING =============== Ground Control Shift G Control Tower Shift T Flight Ops Shift O Approach Control Shift C Landing Signal Officer Shift L WINGMAN COMMANDS ================ F1: Wingman flies to your 4 o'clock position.
F2: Engage/protect my air target.
F3: Resume your mission objectives.
F4: RTB or Return To Base. I use this only when my wingman is low on fuel (he will call "Bingo" when he has just enough fuel left to return to base).
Tactical pre-merge setup:
F5: "Bracket left" or flies to your left side (9 o'clock).
F6: "Bracket right" or flies to your right side (3 o'clock).
F7: "Split High" or flies at your right at a higher level.
F8: "Split Low" or flies at your left at a lower level.
Admin commands:
F9: Echelon. Parade position at your 4 o'clock.
F10: Trail. At your six o'clock.
F11: Combat spread.
F12: Lead. In front of you.
VIEWS ===== Cockpit Views ------------- Forward 1 Look Down 2 External View 3 Selected Target 4 My Aircraft 5 Padlock Target 6 Padlock Nearest 7 Padlock Wingman 8 In-flight Weapon Toggle 9 Radar Target Toggle 0
VIEW MODIFIERS ============== Look Left Arrow Left Look Up Arrow Up Look Right Arrow Right Look Back Arrow Down Optical Zoom In Home Optical Zoom Out End Move Camera In Page Up Move Camera Out Page Down Multiplayer Chat Shift '
AA: Air-to-Air AMRAAM: Advanced Medium-Range Air-to-Air Missile AS: Air-to-Surface HARM: High-speed Anti-Radiation Missile HD: High-Drag LD: Low-Drag LGB: Laser Guided Bomb
STORES DESCRIPTION ================== AIM-9M Sidewinder (190 lbs.) Short-range infrared-guided (heat-seeking) AA missile AIM-9Mx2 Sidewinder (380 lbs.) Short-range infrared-guided (heat-seeking) AA missile AIM-120 AMRAAM (350 lbs.) Advanced medium-range radar-guided AA missile AGM-65B Maverick (645 lbs.) Electro-optically guided AS missile AGM-88 HARM (790 lbs.) High-speed anti-radiation radar-homing AS missile AGM-62 Walleye (1250 lbs.) Electro-optically guided gliding AS missile MK-82 LGB (600 lbs.) Laser-guided general-purpose light bomb MK-83 LGB (1100 lbs.) Laser-guided general-purpose medium bomb MK-84 LGB (2100 lbs.) Laser-guided general-purpose heavy bomb MK-82 LDx2 Slick (1040 lbs.) Free-fall general-purpose low-drag light bomb MK-83 LDx2 Slick (2130 lbs.) Free-fall general-purpose low-drag medium bomb MK-84 LD Slick (1980 lbs.) Free-fall general-purpose low-drag heavy bomb MK-82 HDx2 Snakeye (1160 lbs.) Free-fall general-purpose high-drag light bomb CBU-59B Cluster (490 lbs.) Free-fall anti-personnel and munitions bomb B-57 Nuke (650 lbs.) Free-fall tactical thermonuclear bomb BLU-107B Durandal (483 lbs.) Rocket-powered anti-runway bomb EXT FUEL (2500 lbs.) Disposable fuel tank FLIR (350 lbs.) Forward looking infrared pod / Electro-optical targeting device RECOMMENDED LOADOUTS ==================== Mission Type Station=>Store Patrol 1/9=>AIM-9M, 2/8=>(Empty), 3/7=>(Empty), 4/6=>(Empty), 5=>(Empty) Medium Range CAP (Combat Air Patrol) 1/9=>AIM-9M, 2/8=>AIM-120, 3/7=>(Empty), 4/6=>AIM-120, 5=>EXT FUEL Short Range CAP (Combat Air Patrol) 1/9=>AIM-9M, 2/8=>AIM-9Mx2, 3/7=>(Empty), 4/6=>AIM-120, 5=>(Empty) Escort 1/9=>AIM-9M, 2/8=>AGM-88, 3/7=>EXT FUEL, 4/6=>AIM-120, 5=>EXT FUEL Intercept 1/9=>AIM-9M, 2/8=>AIM-120, 3/7=>EXT FUEL, 4/6=>AIM-120, 5=>(Empty) Ferry 1/9=>AIM-9M, 2/8=>(Empty), 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL CAS (Close Air Support) 1/9=>AIM-9M, 2/8=>AGM-65B, 3/7=>AGM-88, 4/6=>(Empty), 5=>CBU-59B SEAD (Suppress Enemy Air Defenses) 1/9=>AIM-9M, 2/8=>AGM-88, 3/7=>AGM-88, 4/6=>AIM-120, 5=>EXT FUEL Light Free-Fall Strike 1/9=>AIM-9M, 2/8=>MK-82 LDx2, 3/7=>(Empty), 4/6=>(Empty), 5=>EXT FUEL Heavy Laser-Guided (Precision) Strike 1/9=>AIM-9M, 2/8=>MK-84 LGB, 3/7=>MK-84 LGB, 4/6=>(Empty), 5=>EXT FUEL Heavy Free-Fall Strike 1/9=>AIM-9M, 2/8=>MK-83 LDx2, 3/7=>MK-83 LDx2, 4/6=>(Empty), 5=>EXT FUEL Deep Interdiction Strike 1/9=>AIM-9M, 2/8=>MK-84 LGB, 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL Nuclear Strike 1/9=>AIM-9M, 2/8=>B-57, 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL Anti-Runway 1/9=>AIM-9M, 2/8=>MK-82 HDx2, 3/7=>BLU-107B, 4/6=>(Empty), 5=>MK-82 HDx2 Anti-Tank 1/9=>AIM-9M, 2/8=>AGM-65B, 3/7=>AGM-65B, 4/6=>(Empty), 5=>(Empty)
1/30/2014 10:29:01 AM • Xicat... • Answered on Jan 30, 2014
0answers
F/A - 18 Precision Strike Fighter
i suggest that you must go back to old windows xp. it must be incompatible with windows vista. and as far as i know most of the games are not functioning correctly with windows vista cause the game arent built for it. hope that helps!
CHARCOIS
4/28/2009 7:49:02 PM • Xicat... • Answered on Apr 28, 2009
Warrack cheats
He sure does
11/4/2013 12:28:41 PM • Xicat... • Answered on Nov 04, 2013
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information. If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
4/19/2024 1:55:05 AM • Video Game... • Answered on Apr 19, 2024
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
4/14/2024 5:15:47 AM • Video Game... • Answered on Apr 14, 2024
Solitaire Customer Service Call 1-8O5-225-6690 We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
4/13/2024 3:59:39 PM • Video Game... • Answered on Apr 13, 2024
I need the instructions for Electronic Victory at Sea by New Entertainment.
Victory-At-Sea-manual.pdf
Mac Game Store http://cdn1.macgamestore.com > manuals > Victor... PDF To get to the end game you must build your fleet, attack enemy shipping and support landing craft as they attack ports. You can also enter friendly ports and ... 7 pages
Digital Victory At Sea Rules PDF
Warlord Games Store https://store.warlordgames.com > products > digital-vict... This rulebook is the ultimate resource for Victory at Sea players. It contains: The complete rules for fighting naval battles, including the use of aircraft, ... https://www.google.com/search?q=electronic+victory+at+sea+instruction+manual ..
4/10/2024 7:59:57 PM • Video Game... • Answered on Apr 10, 2024
3answers
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
3/13/2024 2:37:53 PM • Video Game... • Answered on Mar 13, 2024
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
3/11/2024 10:00:49 PM • Video Game... • Answered on Mar 11, 2024
2answers
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
3/6/2024 5:46:42 PM • Video Game... • Answered on Mar 06, 2024
Update profile
Hi, Clear your question, because which types of profile update. Then i better answer given. Thanks.
2/26/2024 6:25:45 PM • Video Game... • Answered on Feb 26, 2024
Tritton primer receiver box will not power
If you can buy them from Newegg for less that $6, they can't be that good. https://www.google.com/search?q=Tritton+primer+headset ..
2/20/2024 8:38:52 PM • Video Game... • Answered on Feb 20, 2024
I need a wiring diagram for my Gamepod 1.5 Gaming Chair
No available anywhere and is likely a Chinese maker https://www.google.com/search?q=gamepod+1.5+gaming+chair+wiring+diagram Looks like it just has a pair of speakers and a vibrating box https://www.google.com/search?q=gamepod+1.5+gaming+chair+wiring+diagram ..
2/15/2024 12:00:30 AM • Video Game... • Answered on Feb 15, 2024
A connection error has occurred
I have the same issue as you, we're you able to fix it?
2/9/2024 10:51:27 AM • Video Game... • Answered on Feb 09, 2024
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
12/25/2023 2:12:56 AM • Video Game... • Answered on Dec 25, 2023
I AM TRYING TO GET
well itmight be unconnected or internet turns off
12/13/2023 10:20:47 AM • Video Game... • Answered on Dec 13, 2023
Xicat Interactive F/A -18 Precision Strike Fighter for Windows Logo
Popular Tags
7 questions posted
Top Xicat Interactive Video Game Consoles & Games Experts
Aron
john h
Are you a Xicat Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Xicat Interactive Video Game Consoles & Games
Most Popular Question
get f 18 precision strike fighter
  • Video Game Consoles & Games
