20 Most Recent Robot Coupe R6VN Food Processor Questions & Answers
I purchased a Robot Coupe R101 and wanted to add the Pulse button. Do I just get a R101 Plus switch and front panel? How hard is the replacement? Thanks
To add the pulse button to your Robot Coupe R101, you will need to purchase the R101 Plus switch and front panel. The replacement is relatively simple and can be done by following these steps:
  1. Turn off and unplug the Robot Coupe R101.
  2. Remove the screws that hold the top cover in place and lift off the cover.
  3. Locate the control panel on the front of the machine and remove the screws that hold it in place.
  4. Carefully remove the control panel and disconnect the wires from the old switch.
  5. Install the new R101 Plus switch onto the control panel and connect the wires.
  6. Replace the control panel onto the front of the machine and secure it in place with the screws.
  7. Replace the top cover and secure it in place with the screws.
Once the new switch and front panel are installed, you will have the pulse button on your Robot Coupe R101.
2/24/2023 6:24:36 PM • Robot Coupe Food... • Answered on Feb 24, 2023
I have a Robot Coupe Blixer 4 V series A. The blade is stuck causing the "bowl" to not unlock and come off.
Pour penetrating oil down the upper shaft if possible. Remove the allen scews from the base with 5/32 T handle wrench. Remove the round snap ring on the motor shaft. Use vise grips or channel lock to secure the shaft. Twist the blade off and inspect it. It most likely will need to be replaced as the key that slides on the shaft will have deteriorated.
9/12/2022 5:25:53 PM • Robot Coupe Food... • Answered on Sep 12, 2022
Robot coupe 3b wiring diagram
Wiring diagrams are in the back of the manuals after the parts lists.https://www.partstown.com/robot-coupe/blixer-3b/parts#id=mdptabmanuals..
5/20/2022 10:53:06 PM • Robot Coupe Food... • Answered on May 20, 2022
2answers
Model R602 V.V.F. How can I remove the upper case from the base of the machine?
you look for hidden screw perhaps under a label
5/9/2021 6:53:35 PM • Robot Coupe Food... • Answered on May 09, 2021
Where can I get spare parts for a robot chef food processor RC3
Hi im after a replacement lid for my robot chef rc3 if anyone has a spair one please email me at [email protected]
5/8/2018 9:13:23 PM • Robot Coupe Food... • Answered on May 08, 2018
0answers
Robot coupe food processor RC2800 SN: R2579592 120v 6amp has no power at all, and power supply is good
You will need to find a "small appliance repair shop" in your area, most likely the main PCB has failed, it controls the motor. Check the yellow pages.
8/19/2016 5:48:56 PM • Robot Coupe Food... • Answered on Aug 19, 2016
Robot Coupe R6VN Food Processor Logo
0 questions posted
Top Robot Coupe Food Processors Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Robot Coupe Food Processors
Most Popular Question
robot coupe r301 ultra sling plate
  • Food Processors
