20 Most Recent
Origin Diner Dash: Flo on the Go for Windows, Mac Questions & Answers
I put my game in
If it is in Windows, this happens frequently. You just right click the setup file and click 'run as administrator' and it should work.
As for a Mac, I'm not sure about that.
Activitation code of dinner dash flo ong the go??
Every activation code is unique. Meaning it can only be used once, meaning you can't just share one.
The activation code you're looking for is usually above the disc in the CD box, or on the backside of the manual. It's a 25 letter+number code.
If you have lost the box and cannot find it, you will not be able to activate it since you really need your own unique code.
I need to get codes for these games
Would love to but this is illegal and so please either spend the money or do not use the software. Also please refrain from asking for illegal codes on this site.
How to fix origin not installed in fifa 15
Ciao,
Its the crack thats not ready.
I tried all solutions but nothing works.
Without Origin, installed Origen, offline mode. etc.
Dont spend your time..
We have to wait for the v3 crack.
Ewout
Dse q-1559 Digital Multimeter
hi ,my q1559 is doing exactly the same ,are you using a rechargeable battery that is pretty old ? My point is I put a new battery in and it disappeared . I don't know if this is your problem but try cleaning the test meter probes connector, because the audible warning is telling you have a test lead connected to amps post whilst the switch is not turned onto measure amps..I used a cottonbud it fits perfect soaked in contact cleaner.
Have need for speed run installed on a previos computer have tried to reinstall cannot proceed
In general you can un-install a game or other software from one computer and install on a new one with the same owner and same product key. Sometimes you may need a new product key, and will need to get in touch with the manufacturers.
You do not say what kind of computer/tablet ect you have, but if it uses Windows have you gone to Control Panel>Add or Remove Programs to try and remove it?
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
