20 Most Recent Robot Coupe R2U Ultra Food Processor Questions & Answers
How do I assemble the Robot Coupe R 2 Ultra
Cindy,
Send me your e-mail & I will send you back an exploded view of your Robot-Coupe. It will give all the info needed. [email protected]
6/30/2014 8:30:58 AM • Robot Coupe R2U... • Answered on Jun 30, 2014
Remove pin & replace in work bowl
it takes two to do this. there are two holes on the bottom part of handle. find something strong to push them in. one person pushes them in and have other person with pliers pull on the plug that you need to remove to get to broken pin. after that...replacement is easy
8/5/2011 2:44:49 PM • Robot Coupe R2U... • Answered on Aug 05, 2011
I need wiring diagram for robot coupe r2
Hi
Please check this link..
http://compare.ebay.com/like/150425046495?ltyp=AllFixedPriceItemTypes&var=sbar
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
9/27/2010 1:04:10 AM • Robot Coupe R2U... • Answered on Sep 27, 2010
The robot coupe will stop working periodically
It is overheating, probably because it is being overworked. Some common problems are overloading the bowl, or forcing too much food into the hopper on top. Once it overheats, it will kick out again rather quickly the next time unless the motor has time to cool. If you are shredding cheese, slow down on the amount of cheese forced into the blade. If you are trying to mix heavy dough you are probably overloading the bowl as well. This machine can't handle over a pound of pizza dough without overheating. The reset button is there to keep from burning the motor out. If you continue to reset and force feed the machine, it will burn the motor out. Good luck, hope this helps.
9/11/2010 6:43:55 PM • Robot Coupe R2U... • Answered on Sep 11, 2010
I have a Robot Coupe R2 food processor that quite
It just a long shaft phillips screwdriver. The screws are located under the foot pads. They just pull out and then there are the four screws.
1/6/2010 5:47:52 PM • Robot Coupe R2U... • Answered on Jan 06, 2010
How do I replace the spring on a robo coupe?
Are you referring to the spring in the cutter bowl? You will need to remove the retaining nut. The spring will then come out. the part number for the spring is R1776. Whole assembly part # R242.
Are you referring to the spring in the on and off switch? You will have to replace the switch. If you call Heritage Food Service Equipment, they will be able to fax you a parts break down so that you will know what part is needed. They can most of the time tell you how to replace the parts also. You can contact them at 1-800-253-0200.
10/13/2009 5:21:26 PM • Robot Coupe R2U... • Answered on Oct 13, 2009
I purchased a Robot Coupe R101 and wanted to add the Pulse button. Do I just get a R101 Plus switch and front panel? How hard is the replacement? Thanks
To add the pulse button to your Robot Coupe R101, you will need to purchase the R101 Plus switch and front panel. The replacement is relatively simple and can be done by following these steps:
  1. Turn off and unplug the Robot Coupe R101.
  2. Remove the screws that hold the top cover in place and lift off the cover.
  3. Locate the control panel on the front of the machine and remove the screws that hold it in place.
  4. Carefully remove the control panel and disconnect the wires from the old switch.
  5. Install the new R101 Plus switch onto the control panel and connect the wires.
  6. Replace the control panel onto the front of the machine and secure it in place with the screws.
  7. Replace the top cover and secure it in place with the screws.
Once the new switch and front panel are installed, you will have the pulse button on your Robot Coupe R101.
2/24/2023 6:24:36 PM • Robot Coupe Food... • Answered on Feb 24, 2023
I have a Robot Coupe Blixer 4 V series A. The blade is stuck causing the "bowl" to not unlock and come off.
Pour penetrating oil down the upper shaft if possible. Remove the allen scews from the base with 5/32 T handle wrench. Remove the round snap ring on the motor shaft. Use vise grips or channel lock to secure the shaft. Twist the blade off and inspect it. It most likely will need to be replaced as the key that slides on the shaft will have deteriorated.
9/12/2022 5:25:53 PM • Robot Coupe Food... • Answered on Sep 12, 2022
Robot coupe 3b wiring diagram
Wiring diagrams are in the back of the manuals after the parts lists.https://www.partstown.com/robot-coupe/blixer-3b/parts#id=mdptabmanuals..
5/20/2022 10:53:06 PM • Robot Coupe Food... • Answered on May 20, 2022
2answers
Model R602 V.V.F. How can I remove the upper case from the base of the machine?
you look for hidden screw perhaps under a label
5/9/2021 6:53:35 PM • Robot Coupe Food... • Answered on May 09, 2021
Where can I get spare parts for a robot chef food processor RC3
Hi im after a replacement lid for my robot chef rc3 if anyone has a spair one please email me at [email protected]
5/8/2018 9:13:23 PM • Robot Coupe Food... • Answered on May 08, 2018
Robot Coupe R2U Ultra Food Processor Logo
24 questions posted
Top Robot Coupe Food Processors Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Robot Coupe Food Processors
Most Popular Question
assemble robot coupe r 2 ultra
  • Food Processors
