20 Most Recent
Cerwin Vega Cerwin-Vega E-715 Floor Standing Speaker Pair Car Speaker Questions & Answers
Will the E-715 work at 4 ohms
They will work at 4 ohm, but you won't get near as much volume out of them as you would if you used an 8 ohm amp. The E-715 speakers are rated for 8ohms. You could damage your amp running speakers that are not matched to the same ohm rating, however it is safer to run a low ohm amp to higher ohm speakers then it is to go from low ohm speakers to a high ohm amp. Your speakers will perform how they were intended if you match the ohm rating, so try to do that at if at all possible.
Chris
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
