You can download the manual for free using this link:
http://dl.owneriq.net/8/82dd8645-ef03-4b41-9b07-5a6b02655a1d.pdfSetting and Using the Alarm
1. Press the AL SET button. The time will flash.
2. While the time is flashing press the HOUR button until you reach the correct hour. Then
press the MIN button until you reach the desired minute.
3. After 5 seconds the alarm set time will stop flashing and it will be programmed, or you may press
the AL SET button.
Note: The PM indicator also applies to the alarm. You can review the alarm setting anytime by
pressing the AL SET button.
4. To activate the alarm you may choose one of 3 wake options:
a. To wake to BUZZER press the AL MODE button once.
b. To wake to a SOUND press the AL MODE button a second time. It will set to the last
sound you listened to. If you wish to change it press the sound you wish to
wake to and then press the POWER button.
c. To wake to RADIO press the AL MODE button a third time. You may leave it on the
current station or adjust the TUNER.
Note: A green LED will appear next to the wake mode selected to indicate the alarm is set.
Thanks.
gylacz
