20 Most Recent
Robot Coupe MP450 Handheld Blender Questions & Answers
Braun 4169 disassembly procedure
4169 blender dismantling.
this device is not suitable to be dismantled but this is how I did it.
1 disconnect from the mains.
2 lever off operating lever button at opposite end to hinge
3 insert sharp screwdriver into gap by top lid at same side as cable entry and prise off
4 heat up the casing with an electric paint stripper, wear gardening gloves.
5 when the casing starts to get pliable, insert a driver into the gap above the operating button locating lip and prise away as far as you can
6 do this with the locating peg on the other side
7 work between the two until the whole thing comes apart
8 lever out the motor, it will slide out once loosened
9 wash out the blender drive shaft with boiling water and detergent
10 dry out the body and soak the inside with silicone oil
11 work the blender blade until it spins freely
12 clean everything up and push it all back together
13 if any parts are deformed with the heat gun reheat them to a pliable state and reform them as best you can
14 if it is all loose when its back together, glue the joints with superglue and spray with glue accelerator
15 test it and if it's no good chuck it in the bin and buy a new one
16 but mine works fine.
Disassembling a robot coupe mp450
First you drill out the plastic plugs to acess the torx screws holding the housing together. Remove 4 motor mounting screws to separate from shaft.
ELECTRIC DIAGRAM ROBOT COUPE MP450
I need a wiring diagram too don' Robot Coupe have service info. on their products as expensive as they are it's a problem. Robot Coupe MP450 Turbo can't seem to find anywhere. Thanks
MP 450 TURBO
If you type in your model number on the internet information will come up on it for parts & other things. Hope this helps
NEED TO DIMANTLE A MP450
You have to drill out the little plastic plugs to get to the torx screws holding the housing together
I inherited a braun 4169
see my solution, posted today, 3rd Sept 2010.
if you are not pretty handy at fixing things then don't bother is my advice because even if you manage to get it working ok it still my be unusable.
Does any one know how to dismantle a blender mp
4 screws are covered by caps in the handle area, everyone finds these but there are a further 4 screws found by removing the air vent grilles. The grilles are held in place along their shorter sides midway. Pop a fine screwdriver in at this point and the grille comes off.
Need to know how to
There is an exploded diagram here which should show how it dismantles
http://parts.robotcoupe.net/mp450.htmlNot sure where you are geographically but hope that helps.You can buy the bearings, I was going to suggest that it wasn't worth repairing and then I checked the price of a new one!!!! It is worth repairing I can't believe how expensive they are! Good Luck
Disassemble
we found the solution to the problem on your website.
Thank's for the tip.
Robot coupe mp 450
http://www.retrevo.com/support/Robot-Coupe-MP450Turbo-Food-Processors-manual/id/23109bh930/t/2/
Hope this helps you can download it by PDF
