20 Most Recent Stihl HT101 Pole pruner Questions & Answers
STIHL pole saw 101
Hi Little Bird Chances are that the clutch needs servicing or replacement. Here's a link that explains: http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm Cheers
6/7/2016 5:17:46 AM • Stihl HT101 Pole... • Answered on Jun 07, 2016
Motor runs but everything above motor does not work. how do I take pole from motor?
Either the drive shaft has broken or come detached from the clutch drum at the motor end or the attachment end. Here is the breakdown diagram http://www.mediafire.com/view/a33fr2038d5u1cr
5/15/2016 1:15:10 AM • Stihl HT101 Pole... • Answered on May 15, 2016
HOW CAN I DOWNLOAD A SERVICE MANUAL FOR A HT100/110
By service manual, do you mean the repair manual.? Here is the parts breakdown. Let me know if its not the one you require. http://www.mediafire.com/download/vesj74s704c7rbr
4/13/2016 7:30:34 PM • Stihl HT101 Pole... • Answered on Apr 13, 2016
Oiler not working
could be a blocked oil line, gauze or plugged or damaged oil pump
2/7/2016 2:02:14 PM • Stihl HT101 Pole... • Answered on Feb 07, 2016
Stihl pole saw trimmer is not pulling gas into the cylinder from the carburetor
could be a carb issue, a split in a fuel line, damaged intake boot or gasket
2/7/2016 2:00:01 PM • Stihl HT101 Pole... • Answered on Feb 07, 2016
Fuel lione and filter came off in the tank
This is a simple repair. 1. Drain tank save fuel can be used again 2.Purchase fuel line replacement kit Lowes -Home Depot 3.Kit needs to contain feed wire and gas hose. 4.Disassemble cover to reveal fuel line connection to carb. 5. Feed wire from kit into fuel tank through fuel line hole. 6. Install new hose over wire connecting end into hook at end of wire 7. Pull hose through tank up to the carburetor 8. Remove wire and connect filter and hose to carburetor 9. Replace gas into tank, Ck for leaks
11/15/2015 4:29:43 PM • Stihl HT101 Pole... • Answered on Nov 15, 2015
Will not start
could be no spark or no gas getting to engine
3/8/2015 1:08:43 AM • Stihl HT101 Pole... • Answered on Mar 08, 2015
Change gas filter in tank
hook out the fuel line and filter with a hooked rod, pull off the filter and push new one onto the pipe
3/7/2015 9:05:18 PM • Stihl HT101 Pole... • Answered on Mar 07, 2015
Greasing the drive shaft
yes grease the drive shafts. there is no greasing point, you have to remove the attachment and remove the inner shafts. Heres the manual, hope it helps http://www.mediafire.com/view/a33fr2038d5u1cr
3/7/2015 9:01:51 PM • Stihl HT101 Pole... • Answered on Mar 07, 2015
Attaching line from gas tank
3/7/2015 8:50:02 PM • Stihl HT101 Pole... • Answered on Mar 07, 2015
Stihl ht101 blade stalls when slight pressure applied to bade
I'd say you have a fouled plug clean it up and regal it or replace
2/19/2015 1:45:06 AM • Stihl HT101 Pole... • Answered on Feb 19, 2015
Saw not firing
make sure that you left a 10 thou air gap between the armature leg and magnet.
10/18/2014 5:17:41 PM • Stihl HT101 Pole... • Answered on Oct 18, 2014
Changing drive shaft
You should be able to just pull it out, it just slides into the clutc drum. It be stuck from rust, speay some WD-40 on it an let it set for a while, also try tapping on the clutch drum lightly with a hammer as you pull on the shaft. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_a3dac712db4ca1a6
6/22/2014 2:17:50 PM • Stihl HT101 Pole... • Answered on Jun 22, 2014
How do I set the timing
Are you trying to set the ignition or valve timing ? The ignition timing is factory set and changes with engine rpm - you can set the air gap between the flywheel and the ignition unit which should be around 0.25mm (0.010") Excessive air gap will retard the ignition timing. Unless you\'ve had the engine apart, the valve timing won\'t need re-setting. The valve clearances will need setting from time time and the clearance between valve and rocker is 0.1mm and is adjusted with both valves closed and piston at the top of it\'s stroke - you should replace the gasket and copper washer at the same time.
5/11/2014 10:51:12 AM • Stihl HT101 Pole... • Answered on May 11, 2014
Stihl ht 101 spare parts list pdf
Stihl does not supply parts lists to the public. if you want one you will have to talk to a dealer in your area and see if they will be willing to allow you to look at one If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
4/18/2014 12:23:04 AM • Stihl HT101 Pole... • Answered on Apr 18, 2014
Stihl HT 101 Telescopic Drive Tube is rotating
Sounds like the baring block on the end of the extention section has come loose, they are held on by a rivet. remove the clamp by slackening it off and tapping the whole bracket off the main tube to expose it.
8/29/2013 7:07:30 PM • Stihl HT101 Pole... • Answered on Aug 29, 2013
Stihl HT101 Pole pruner Logo
32 questions posted
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
View Most Popular
Stihl Garden
  • Stihl Garden
Most Popular Question
changing drive shaft
  • Garden
