20 Most Recent Riccar 8850 Vacuum Questions & Answers
The armature should be cleaned and dressed when the brushes are replaced as they get full of carbon and can spark.
Riccar 8850... | Answered on Feb 11, 2018
Remove the bottom plate to be able to pull the light bulb out and replace it.
Riccar 8850... | Answered on Jun 03, 2016
Contact me at 800 538-6501 and I will get the information you need to get and install the parts you need. Thank you.
Gary,
Aladdin / That Vac Guy
Riccar 8850... | Answered on Apr 03, 2016
adjust the setting on the vacuum head to pile or plush carpet
it is a simple lever that raises the hood to allow more air under it to make it easier to push
Riccar 8850... | Answered on Oct 07, 2015
There is not a pulley missing, when the belt is tight the shaft will turn the belt but when the belt loses elasticity it will slip on the shaft when being used on the carpet. Replace the n
belt at least once or twice per year.
Riccar 8850... | Answered on Mar 06, 2015
On the back towards the bottom
Riccar 8850... | Answered on Jan 13, 2015
If it has no suction it most likely is clogged
The knob is to reduce the amount of suction. It normally should be closed.
Reset button is on the back towards the bottom.
Inside the bad compartment you can see the swivel portion sticking through. You will need to take a screwdriver and push in on the tabs on the swivel to release it so it can be removed from the body of the vacuum. The new hose ans swivel will just push into the hole and the tabs will hold it in.
Riccar 8850... | Answered on Jan 03, 2015
There are a few parts in the agitator but not many need to reinstall it. Your vacuum is over 10 years old. To insure many more years of service have it checked by your local Riccar dealer.
Riccar 8850... | Answered on Aug 11, 2014
The belt has probably lost elasticity or the clutch needs adjusted or a new rubber pad.
Riccar style A or B bags will fit. So will Panasonic U, U3 or U6.
On the back down by the bottom left side. it's a little white button by the tag that says "reset button"
The button will not push in unless it has been tripped. Your model is well over 10 years old, it could be the power cord, the switch or a loose wire somewhere.
If it spins freely the belt is probably broken or it needs adjusted or has a worn part. This is an inexpensive thing for your Riccar dealer to do when you have your vacuum serviced.
Remove the assembly that holds the foot pedal by removing the three screws after you've removed the bottom plate and brush roll. This allows you to get the nozzle housing out of the way so you can rotate the assembly holding the foot pedal from the metal pivot. Remove the e clips from the shaft and pull the shaft out of the foot pedal (be sure to look closely at the spring and how the shaft are positioned so you can be sure to install them exactly the same way you took them off. It is not a hard job but can be confusing the first time. It's not an expensive fix to have done by your Riccar dealer.
The carpet / floor selector moves a rod which adjusts the clutch, Your model is over 10 years old, it may need a new belt, clutch rubber pad or just need adjusted. If you don't know how to perform these services take your vacuum to your local Riccar dealer for service. It's the least expensive way to keep it working properly for many years.
Your 8850 is an old vacuum. If a new belt does not solve the problem it may need a new rubber motor mount or metal pivot. Both parts are inexpensive and available from your Riccar dealer. If it's been a while since it's been serviced it would be wise to have it serviced by your dealer. A Riccar vacuum will last for many years but should be serviced once a year like all vacuums.
Vacuums Logo
65 questions posted
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
rebecca curry
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Riccar Vacuums
  • Riccar Vacuums
Most Popular Question
cannot get cover off hepa filter
  • Vacuums
