20 Most Recent
Frigidaire FPCO06D7MS Professional 6-Slice Convection Toaster Oven Questions & Answers
What does error code e02 indicate?
I had one with the same problem. I found out that this was due to a defective temperature sensor (in my case anyway). The technical name for this part is NTC glass encapsulated thermistor 86k ohm. It is placed against the outer right wall of the toaster oven. if you look into the oven,there are 2 screws holding it( this device is on the other side of the wall and is connected to the controller via a 2-pin white connector. I replaced it and my toaster oven works fine after. This part costs about 1-2 dollars to replace. You have to remove the top cover of the toaster oven to have access to it.
