20 Most Recent
J4constructioncom Just Single Bowl Dishwasher, Ge Group Topmount Stainless UJ123954 Questions & Answers
DIO3T131FEUK Integrated dishwasher has power but won't switch on
Check Power Supply:
First, ensure that the dishwasher is properly plugged into an outlet. Sometimes vibrations or nearby appliances can cause it to come unplugged.
If it's plugged in, test the outlet by connecting a small appliance (like a toaster or blender) to see if it turns on. If it does, move on to the next step.
Check Circuit Breaker:
Verify if a circuit breaker has tripped. Go to your circuit breaker box and look for any tripped breakers.
If you find one, flip it to the "off" position and then back to the "on" position.
Test the dishwasher again to see if it powers on.
Child Lock or Delayed Start:
Some dishwashers have a child-lock feature that prevents accidental starts or changes to the wash cycle.
Check your owner's manual for instructions on disabling the child lock or delayed-start features.
Ensure that the dishwasher door is securely latched.
Reset the Dishwasher:
If the dishwasher has power but won't start, it might be stuck between cycles.
Allow any drain cycle to run (if applicable), wait for 60 to 90 seconds, and then press the start button once.
Unplug the dishwasher for a minute or two, then plug it back in. This can help reset the machine.
Refer to the owner's manual for any specific reset procedures.
If none of these steps resolve the issue, consider reaching out to professional repair services or the manufacturer for further assistance.
4/21/2024 2:44:15 PM •
Dishwashers
Answered
2 days ago
Karcher Puzzi 100 Spray pressure low
troubleshoot the issue:
Spray Nozzle Blockage: Ensure that the spray nozzle is clear and not blocked. Sometimes debris or buildup can obstruct the nozzle, affecting the spray performance.
Pump Coil and Circuit Board: The pump coil could be damaged or broken. If it's faulty, the pump won't spray at all. You can check continuity through the coil and verify that the switch is supplying power to the circuit board and, in turn, to the pump. Dry solder joints or a failed smoothing capacitor on the circuit board can also cause issues. Pumps are relatively simple solenoid plunger types, and replacements are available for around £40-£50. If you're not comfortable testing at mains voltages, seek professional assistance.
Calcium Buildup and Blockages: Some pumps can be dismantled, allowing you to remove any calcium buildup or blockages. Gently tapping or shaking the pump might get it going. Recirculating a descaler can also help clear buildup without disassembly.
Pump Replacement: If the pump is indeed faulty, consider replacing it with a new one. It's advisable to change the circuit board (PCB) as well. If you're unsure about electrical testing, consult an expert.
Remember to follow safety precautions when dealing with electrical components. If you're not experienced, seek professional help to avoid any risks. Good luck with resolving the issue!
For reference, the Karcher Puzzi 100 is designed for gentle and effective cleaning of small to medium surfaces, especially carpets and upholstery2. Its spray pressure is around 1 bar, and the spray rate is approximately 0.26 gallons per minute. If you need further assistance, consider referring to the Karcher Puzzi 100 user manual.
4/20/2024 10:55:08 PM •
Dishwashers
Answered
3 days ago
Can't get dishwasher out from underneath the counter
Question edited to move it from Computers to Dishwashers.
Is there by any chance a floor tile 4" out from the dishwasher front? If so, try lifting the front with a crowbar or long screwdriver.
Did you disconnect, inlet hose, drain and power? They may have been installed tight, or clipped.
4/19/2024 6:24:59 PM •
Dishwashers
Answered
on Apr 19, 2024
HOW TO REPAIR A HOLE IN MY DISHWASHER
It depends upon the material you are trying to repair but Araldite or any good quality two part epoxy will suffice to fill the hole.
Ensure the area is dry and clean then build up the repair . Larger holes will require multi additions of epoxy.
4/15/2024 10:01:23 PM •
Dishwashers
Answered
on Apr 15, 2024
WINTERHALTER MODEL MTR3 GIVE ME ERROR 22.2 AND ERROR 12.1
These error messages both point to a sensor problem.
Error 12.1
This error is related to the boiler temperature sensor. Consider the following:
Look for a short circuit in the sensor. Inspect the cables and plugs for any issues.
Ensure the sensor is correctly connected.If needed, replace the boiler temperature sensor.
Error 22.2:
This error pertains to the tank temperature sensor. Possible causes include:
Short circuit in the sensor.
Cable failure or plug failure.
Sensor not properly connected.
You may need to check the sensor wiring, connections, and replace the temperature sensor if necessary.
4/3/2024 6:11:13 PM •
Dishwashers
Answered
on Apr 03, 2024
What year is this Kenmore dishwasher Model # 665.15831791 made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. This dishwasher was manufactured by Whirlpool. The following link explains how to determine when it was manufactured:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The serial number is usually located somewhere around the door opening. The first two numbers in the serial number identify the WEEK it was manufactured (52 weeks in a year). The second DIGIT in the serial represents the YEAR it was manufactured.
If you have difficulty determining the manufacture date, please post back with your serial number and I will assist you. I hope you find this information helpful.
3/12/2024 6:43:46 PM •
Dishwashers
Answered
on Mar 12, 2024
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
2/4/2024 12:34:17 PM •
Dishwashers
Answered
on Feb 04, 2024
