20 Most Recent
Trekstor i.Beat Xtension MP3 Player Questions & Answers
Beste heer ik heb een
Welke extensie gebruikt het. blablabla.mp4 of iets dergelijks?
Daar moet u het in zoeken windows kan waarschijnlijk de extensie niet openen omdat u niet de juiste software gebruikt die ervoor gemaakt is, dus ik zou bij de fabrikant gaan zoeken naar een programma voor windows wat het wel kan openen.
Mijn eerste Nederlander die iets in het Nederlands vraagt, ha bonuspunten!
How do i load stuff
You can download the complete instruction manual (multi-lingual) in PDF format by clicking this
link.
- You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
How do i download music into mp3 player
go to my computer and there will be a title that says "devices with removable storage" click on the device you are using and a folder will appear. then copy and paste your songs in to that folder.
Then after you are done selecting your music and putting it on the device, take the device out of the computer and listen to your music.
Unknown Format
It is not the MP3 player but the DRM copy protection on the cd. DO NOT BUY CDs WITH DRM PROTECTION. There are ways around the DRM - rip the cd into another format with software designed for this purpose.
Software missing or software update
You can list out many things that play around you, having software in it. Without software, there would have been no such thing called 'Google' or maybe, we wouldn't have known 'Any better way to exchange knowledge through the internet as a medium. The software can be written by anyone, who wants to see something that can work for every other person in this world. 'Look around! Its software running behind at Vilmate
https://vilmate.com/service/software-development/
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
