20 Most Recent
Prepology 4qt Microwave Pressure Cooker with Extra Gaskets - Yellow - Questions & Answers
Hello my Teka MCX 45.1 BIT microwaves start button not appearing?
Microwaves generally last about 2000 hours before losing power. Here are some basics to try: Make sure the power plug is securely plugged into the wall outlet. Listen for an audible click when you close the door. Unplug it, wait 30 seconds, plug it back in (this may reset it). If the start button is then not appearing, there may be a problem with the touchhpad or control panel. Teka's customer service:
https://www.teka.com/global/support/
What cause the high voltage fuse to damage
Based on the fact it is not said where it is used or how it blows i.e. does it blow as soon as power is applied or does it blow after a few seconds? In the first case you probably looking for direct short while in the second case a faulty item that is becoming defective when energized or hot.
My bowl is stuck on
I have the same problem now its the second time it got stuck. The manuals say not much. :(
My wave guide is terribly burnt. Can it be fixed or do I need a new microwave? Hisense- Model no: H25MOMS7H.
If your microwave's waveguide cover is severely burnt, it is generally recommended to replace it rather than repair it. The waveguide cover is designed to be transparent and protect the antenna or magnetron from food splatter and grease. To replace the cover, follow these steps:
1. Identify the replacement part number from your microwave's user manual or contact the manufacturer.
2. Order the part from the manufacturer, authorized dealers, or reputable appliance parts suppliers.
3. Turn off the microwave to ensure safety.
4. Remove the old waveguide cover and secure it using screws or clips.
5. Place the new waveguide cover in the same position and secure it using the appropriate screws or clips.
6. Test the microwave to ensure the new waveguide cover is in place and functioning correctly.
Replacement is crucial as a burnt or damaged waveguide can affect the microwave's performance and cause further damage to internal components. If you have any doubts or are uncomfortable with the replacement process, seek professional assistance or contact the manufacturer's customer support for guidance.
How might I set the clock on toshiba er7900
There are different patterns to setting a microwave clokc, depnding on the brand and age.Try these combinations (both with the door open and with door closed) to set the clock to 1:00:Clock > 1 > 0 > 0 > StartClock > 1 > 0 > 0 > ClockClock > Clear > 1 > 0 > 0 > StartClear > Clock > 1 > 0 > 0 > Start
My model number ogcmdm 11s2-10 how to replace broken door latch hook key P6OD17L-D1
It appears there might be a mix of information in the provided details. However, based on what you've mentioned, it seems you're dealing with a broken door latch hook key on a device with the model number "ogcmdm 11s2-10." Unfortunately, the information provided doesn't align with known model formats or specific products, and I might not have detailed information about this particular model or device.
Given that, here are some general steps you can follow when dealing with a broken door latch or lock:
- Identification of the Latch or Lock:
- Identify the type of latch or lock system used on your device. It could be a simple spring latch, deadbolt, or a more complex mechanism.
- Obtain Replacement Parts:
- If the latch hook key is broken, you may need to obtain a replacement part. Contact the manufacturer or a supplier to inquire about replacement latch hook keys or the entire lock assembly if necessary.
- Accessing the Broken Part:
- Depending on the design of your device, you may need to disassemble or remove certain components to access the broken latch or lock. Refer to the device's user manual or any available documentation for guidance.
- Remove Broken Parts:
- Once you have access to the broken latch or lock, carefully remove the broken parts. This may involve unscrewing screws, removing panels, or disassembling components.
- Install Replacement Parts:
- Install the replacement latch hook key or lock components following the manufacturer's instructions. Ensure that the new parts are compatible with your device.
- Test Operation:
- After replacing the broken latch or lock parts, test the operation to ensure that the door can be securely locked and unlocked.
- Reassemble:
- If you had to disassemble any components to access the broken part, reassemble the device according to the manufacturer's instructions.
If you encounter difficulties during the process or if you are unsure about how to proceed, it's advisable to contact the manufacturer's customer support for specific guidance or consider consulting with a professional technician.
Please note that the general steps provided may not cover all possible scenarios, and the actual process might vary based on the specific design of your device.
