20 Most Recent Kenmore 23.3 cu. ft. Side-by-Side Refrigerator 5137 Questions & Answers
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Kenmore 23.3 cu.... | Answered on Aug 03, 2017
The hinges are adjustable
Kenmore 23.3 cu.... | Answered on Jan 11, 2013
What is the model number?
Kenmore 23.3 cu.... | Answered on Nov 10, 2012
yes
Upright Freezers ' Kenmore
https://www.kenmore.com/products/refrigeration/freezers-and-ice.../upright-freezers/
Kenmore upright freezers are great for the garage, basement, or pantry. ... These freezers come with a manual or frost-free defrost system, to keep rarely used foods from expiring early. ...
Kenmore Freezers | Answered on Jul 24, 2019
It may be a sensor. Don't replace a control center unless you have determined it's bad. The sensor has to be wired to the board controller. Usually smaller cable with 2 conductors. If it has an alarm then there may g e as many as 6 or 8 or more wires going to the board. Using your wire diagram Find the sensor for temp. Sometimes the ohm value is given on the wire diagrams. You will also need the temperature at the point the sensor is connected inside. Your ohm reading should be close to the temp given in a table or from the manufacturer. If it's close sensor ok. Take next step.
Kenmore Freezers | Answered on Jan 18, 2019
Does it have a high temperature alarm? I have an older Kenmore with this that requires a 9 volt backup battery to activate the alarm if the power goes off. If the battery goes dead over time, the alarm won't shut off even with the power on. My battery is behind a small door on the left side end of the plastic floor dress plate on the bottom front of the freezer. I use a 9 volt lithium battery myself. I have a backup generator so it doesn't have a lot of time to run on the battery. Where an alkaline battery lasts me about 18 months, This lithium battery has been in for 3 years and shows no sign of failing yet. They have a shelf life of 15 years or more all though they won't last that long in this application. It's worth not coming home and not finding the dogs going wild due to the high pitched beep. Good luck.
Kenmore Freezers | Answered on Dec 31, 2018
Never heard of an electric freezer with a 9v battery. What is freezer model #?
Kenmore Freezers | Answered on Nov 20, 2018
For bottom freezer 111 models:
The control detects low refrigerant charge or a defective compressor. A refrigerator service technician will need to complete this repair because it involves the recovery and recharge of refrigerant (Freon).
Kenmore Freezers | Answered on Nov 11, 2018
Consult your owners manual but maybe it’s to designate Fahrenheit as opposed to Celsius
Kenmore Freezers | Answered on Oct 28, 2018
What is model # and why would it have a 9v battery?
Kenmore Freezers | Answered on Oct 22, 2018
most all appliances are designed to be in an ambient not to exceed 80 degrees. Units will function but not up to design specs and would really strain to work. Only commercial unit can survive in temps up to 95 degrees in the Southeast U.S. and this temp varies depending on your general location.
Kenmore Freezers | Answered on Aug 13, 2018
First question would be, is the compressor running? If yes, then there is a refrigeration issue. If no, then there is either a control issue or compressor component issue. We really need to do the question and answer "game" in order to troubleshoot. Let me know if I can be of any possible help. Good luck!
Kenmore 23.3 cu. ft. Side-by-Side Refrigerator 5137 Logo
Popular Tags
7 questions posted
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
kenmore elite 51374 refrigerator
  • Freezers
