20 Most Recent True T-23F 23 Cu. Ft. 1 Door Freezer Questions & Answers
Your freezer compartment will freeze up and not cool properly if the defrost timer does not allow the unit to go into its self defrosting mode to get rid of the ice that serves as an insulator.
Replace the timer.
True T-23F 23... | Answered on Jan 20, 2015
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
True T-23F 23... | Answered on Apr 18, 2013
tru would be a possible source.
True Freezers | Answered on Mar 10, 2019
I am assuming you are relating to the evaporator fan(s) not running. If this is the case, some units have a 'Klixon" type thermostat in the evaporator so when the evaporator coil temp reaches a predetermined temperature, the fans come on. You may have a bad "Fan Delay" (Klixon) or the coil is not reaching the proper temp to activate it to turn on the fans. I would check the wiring diagram on the unit for this part to see if this unit has it in the system.
True Freezers | Answered on Jun 12, 2018
call a repair service we do not have testing facility
True Freezers | Answered on Jan 31, 2018
ofcourse you should have it checked or BUY A NEW ONE
True Freezers | Answered on Jan 10, 2018
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf
This web site has the manual for this freezer. Take a look and see if this answers your question.
True Freezers | Answered on Sep 11, 2017
Request the wiring diagram directly from True.
True Freezers | Answered on Feb 22, 2017
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf. Check out this manual. has instructions.
True Freezers | Answered on Feb 11, 2017
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf. check out this manual. has instruction for lots of what you want.
Only from the manufacturer.
True Freezers | Answered on Nov 03, 2016
if seals are in good condition
no sizable water leaks from cabinet
one should suspect the thermostat is no shutting off compressor
test or replace thermostat
True Freezers | Answered on Oct 08, 2016
Dirty coils, or refrigerant getting low
True Freezers | Answered on Nov 11, 2015
Most all true units have digrams on the unit. May have to pull covers to find them
REPLACED COMPRESSOR ON FREEZER TRUE AIR 3/4 HORSE POWER 115V
True Freezers | Answered on Sep 16, 2015
If it has electronic controls, you will need the manual. On manual commercial freezers the knob is in the back of the upper unit on the right hand side. They are a good make, I have had a number of them.
http://www.truemfg.com/
True Freezers | Answered on Aug 13, 2015
True T-23F 23 Cu. Ft. 1 Door Freezer Logo
4 questions posted
Top True Freezers Experts
Dennis Boxerman
Joe Palazola
John Carter
John Carter
Level 1 Expert
Are you a True Freezer Expert? Answer questions, earn points and help others
View Most Popular
True Freezers
  • True Freezers
Most Popular Question
freezer not cooling properly defrost
  • Freezers
