20 Most Recent True Direct Draw Systems: Kegerator TDD-3CT Questions & Answers
Kegerator not cooling
which fan , inside or out.. if outside condensor fan is running then it has a bad 175 capacitor or if the compressor is running then it is low on refrigerant. if the cond fan is not running then check thermostat.. you can do this by connecting the two wires together.. another way to check the compressor, cond fan is to reach under and unplug the wires going to comptessor and plug into a 12ga extention cord.
5/22/2014 5:49:44 AM • True Direct Draw... • Answered on May 22, 2014
Replacing true kegerator parts
no use a Ranco p# A12-700 make sure the capillary is in the coilto sense the temp and set it to 1.5 on the knob. any colder and it could get too cold . you may be able to set it at 2 but be careful. it is a constant cut in at 37 degrees coil temp. the box temp will drop to usually to 28 or 29 at cut out.
4/18/2013 3:01:02 AM • True Direct Draw... • Answered on Apr 18, 2013
True T-49F 55? 2 Door Solid Reach In Freezer. How to solve error code E1 on freezer Tru T49f?
Question edited for clarity. Question moved to maker category. Thermostat Probe Error
E1 error on a true freezer. True Freezer, 5yrs. Just
JustAnswer https://www.justanswer.com > Appliance Repair Mar 6, 2022 - Ok. The E1 error code indicates a thermostat probe failure. 1 answer · Top answer: Hi, welcome to JustAnswer. My name is***** am a ticketed HVAC and refrigeration technician with ...
True Refrigeration Troubleshooting
Parts Town https://www.partstown.com > resource-center > guides P1 Alarm/ E1 Code. What does it mean? - This indicates a thermostat probe failure. "P1" displays on units with Dixell electronic controls. "E1" . ..
4/12/2024 3:24:01 PM • True Freezers • Answered on Apr 12, 2024
True T-23F Single door freezer. My freezer isn't running?
Question edited for clarity and better English. Low on Refrigerant Gas. You need a refrigeration engineer.
10/12/2023 3:39:09 AM • True Freezers • Answered on Oct 12, 2023
True T-49F 55", 2 Door Solid, Reach In Freezer. It sounds like it is one but it is not getting even cool? True Freezer.
Question edited for a lot more clarity. Question moved to True Freezer category. You need a refrigeration engineer. It sounds like is has a leak and needs topping up with refrigerant gas. Things that also need checking, circulation fan working and that the defrost timer and defrost heater, and electronic thermostat are working correctly. Refrigeration is not a handyman job. ..
4/14/2023 4:33:18 AM • True Freezers • Answered on Apr 14, 2023
My true freezer will not freeze...everything turns on but tye fan inside....please help!!!
Your fan it's either defective, Or your unit is frozen up and the fan is stuck in ice. Unplug it defrost it take off the panels and see if the motor's any good .
6/2/2022 5:08:58 AM • True Freezers • Answered on Jun 02, 2022
2answers
No door heat
The Mulluen heaters will be Built into the frame not in the door.
1/10/2022 5:01:22 PM • True Freezers • Answered on Jan 10, 2022
I have true freezer t-19 that's not getting cold.it turns on but that's about it
we are not freezer repair tech , call one local to you
5/31/2021 9:44:39 AM • True Freezers • Answered on May 31, 2021
On freezer True T-23, the compressor works around 5 minutes and turn off for around 5-6 minutes and start again for another 5 minutes. I need help
That is what it is supposed to do. It is called cycling and switches off when the set temperature is reached. It is a commercial freezer, so if the door opened and closed often, that is normal?Commercial freezers and fridges have an item called a 'Clixon' that cuts power in the case of the compressor overheating. When was the last time the fins on the compressor coils were cleaned? Could also be a bad door seal letting cold air escape. When you close a freezer door on a unit like that, it should be really hard to open straight afterward due to the suction. Could be a faulty thermostat. Turn the temperature to the warmest setting and see if it still does it? If it does, you need a new thermostat.I just retired after 52 years in catering.https://www.katom.com/598-T23F.html?gclid=CjwKCAiArbv_BRA8EiwAYGs23PKtEzF60_OMVNpHXBlGjHQNdpp0pDZsu0G0lFLqVy2p4qIybG9n8xoCwEMQAvD_BwE..
1/1/2021 9:38:12 PM • True Freezers • Answered on Jan 01, 2021
Why is jenn air jcd2389ge hot around front freezer door frame?
The heat at the opening of refrigerator is usually a sign the condenser coils are dirty. Check the condenser coils for a restriction underneath the unit. Dirty condenser coils will cause poor air flow over the coils and compressor. Poor air flow will cause a lot of problems, including overheating the compressor, the refrigerant and the copper lines. This will destroy your sealed system. The coils need cleaning at least once a year, more often if you have pets.
I couldn’t determine if your unit has an “energy saver” setting. If so, turn it on. Not all refrigerators have energy saver. This is on units with emilion heaters in the wall around the door gaskets. The heaters are to eliminate condensation around the door. Turning ON energy saver turns OFF those heaters. You should notice a change quickly if it’s the heater causing the heat, that is, if you have that model.
Cleaning the coils will need a day or two to allow things to cool down before you notice a change in the heat around the door.
7/29/2019 4:27:08 AM • True Freezers • Answered on Jul 29, 2019
Can the temperature be adjusted on the true GDM-49F
https://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-GDM_iom.pdf Here is the site for the ops manual. should walk you thru how to do temp adjustments.
11/19/2018 11:10:04 PM • True Freezers • Answered on Nov 19, 2018
True 49f fans stopped running. Compressor still runs. Fixes? Troubleshooting steps?
I am assuming you are relating to the evaporator fan(s) not running. If this is the case, some units have a 'Klixon" type thermostat in the evaporator so when the evaporator coil temp reaches a predetermined temperature, the fans come on. You may have a bad "Fan Delay" (Klixon) or the coil is not reaching the proper temp to activate it to turn on the fans. I would check the wiring diagram on the unit for this part to see if this unit has it in the system.
6/12/2018 12:18:22 AM • True Freezers • Answered on Jun 12, 2018
How do i adjust the temp on my True T-23 Freezer
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf This web site has the manual for this freezer. Take a look and see if this answers your question.
9/11/2017 1:18:34 AM • True Freezers • Answered on Sep 11, 2017
T 23. How do I adjust the temperature ?
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf. Check out this manual. has instructions.
2/11/2017 11:23:25 PM • True Freezers • Answered on Feb 11, 2017
True Direct Draw Systems: Kegerator TDD-3CT Logo
4 questions posted
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
View Most Popular
True Freezers
  • True Freezers
Most Popular Question
kegerator not cooling
  • Freezers
